Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
my t04z is a split pulse t4 flange - same as the GT3788. The 4088R is a bigger turbo than the T04Z (compressor and turbine) so it will flow more HP, with a tiny bit more lag.
Main reason for doing the swap is simply that the Z is too doughy out of medium tight corners around the track. IE: turns 3/4 @ QR I take at about 80km/hr. 2nd gear == massive tailslide on exit, whilst 3rd gear == LAG all the way out of the corner. Hopefully the new turbo is not only slightly more responsive, but a lot more linear in power delivery. I make 1 bar at 4100rpm with the Z and 24psi at 4500. Thats not too laggy, but as soon as you go below 4000 rpm there is absolutely nothing there. I wouldnt care too much if the 3788 only makes 1 bar at 4000rpm as long as 3800/3900 still had SOMETHING available unlike the Z which comes on like a lightswitch once you get over 4.
The only unfortuante thing is that I wont be able to directly compare how the 2 turbo's would have worked on the track as I'm making some other significant changes to the car at the same time. So wont be able to say if the 3788 is soley responsible for better lap times, but hopefully combined with everything else we are doing it makes a big difference.
Still probably a couple of weeks away from doing the swap - will see how we go.
What else are you doing mate!?!?!!?!?!?
Is it going to be ready for the 11th?
We are going to run high boost on the T04z this time and see what we can times we can squeeze out of it.
Hopefully the new balancer will keep all the belts on the car unlike last times sad effort!
#### Couldnt edit my first abortion of a sentence.
this should make more sense
We are going to run high boost on the T04z this time and see what times we can squeeze out of it.
Oh few bits and pieces. Got some softer suspension going in as the 12kg springs that were on there were way to hard. The car will definitely be there on the 11th even if i have to push the damn thing around the track :D
hopefully catcha then ! Look forward to seeing what you can do with the good ole Z :P
Oh few bits and pieces. Got some softer suspension going in as the 12kg springs that were on there were way to hard. The car will definitely be there on the 11th even if i have to push the damn thing around the track :banana:
Nice mate,
Looking forward to seeing your new setup in action!
Wont be able to say if the 3788 is soley responsible for better lap times, but hopefully combined with everything else we are doing it makes a big difference.
Are you running an RB30? 1bar at 4100rpm isn't that bad :thumbsup:
Strictly speaking the GT4088R isn't really a bigger turbo than the T04Z, the T04Z has a bigger compressor which wants to flow a bit more air - the Supra guys in the States and the UK seem to be increasingly moving from the T04Z to the GT4088R as the fun 700+ish turbo to have, the GT4088R is apparently more useable and generally fun.
Look forward to hearing how the GT3788R treats you, I've never heard of one used on a petrol motor.
sounds like rb26 response.... in 4th gear on a flat road loading up the motor i was getting 1bar around 3700rpm on my stock capacity rb26
Smoking Crack whilst driving helps Cerbera think the boost is coming on sooner.
Also Cerbs .... 139mph last night with a GT35 !!
ANDRA guy got angry and told me to get a chute ..... jeeeeeez never ends !
Good job, I guessed your weight at 2800lb?s and put your run in the Power calculator and it came up at 560hp so the numbers sound right.
http://www.turbofast.com.au/Drag.html
Reasonable guide but remember its engine power. Im surprised just how close this has been.
dam id love to see a skyline run 139 at the plex, where are u getting ur E85 from in perth?
silvia even
Edited by ahh 33 s2
Running 1000cc injectors and low rail pressure. It gets to 90%.
Not sure how the pump would fair on higher rail pressure but in theory a lot more injector available.
Are you running an RB30? 1bar at 4100rpm isn't that bad :P
Yea, the compressors of the 2 turbo's are fairly similar in the scheme of things ->
TO4Z
Inducer 66.7mm
Exducer 84.0mm
Turbine: 74.2mm
4088R
Inducer 63.5mm
Exducer 88.0mm
Turbine: 77.0mm
Doesn't the exducer determine how much air it can flow ? People seem to be getting a bit more HP out of the 4088's than the Z's.. the fin design of the new garrett turbo's is more efficient than the older Z's.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
