Probably a question for Sydneykid...
My 33 came across to the Aussie side with an aftermarket Chipped ECU. The car was labled a freak cause it constantly made 10-15kw more than any other car with the same mods.
A strange thing occured to me, the VCT with the "chipped ECU" wasn't being activated untill 5000-5500rpm. Also was running massive timing advance. I am wondering if there is any advantage from doing this???.....I can't see how there could be unless it has a different inlet cam. Anyway felt really cool, sort of had three power bands.
https://www.sau.com.au/forums/topic/24647-controlling-vct-on-rb25det/
I thought the vct on thr RB25 was activated on startup and acted to improve low to midrange torque cutting out at some point in the higher rev range. My EMS computer is supposed to optimise performance by setting the optimum point to cut out the VCT to give the best output for both low and high revs
VCT on teh RB25 is activated in the lower/mid range
~2000rpm
Im running a Wolf v4, and while we were initially tunning it we had some time to fool around with the VCT on the dyno
We did a comparo by changing its activation point and basically the conclusion we came with is its best left where its designed for
We had it active "ala honda vtec style" higher up in the rev range and it wasnt as efficient in making power as it was lower down inthe lower to mid range
hope this helped
as whistla said it works best where its designed for.
i dont think the nissan engineer's put in that operating range because they can , they have spend a hellofa lot more R&D then any of us ever could..
if you want to help the VCT work more effectively try a adjustable exhaust cam wheel .
I was waiting to find this: http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html or something similar until I posted:)
NVCS comes in just over 1000 rpm and cuts out at 4500rpm on RB25DET.
the best way I have heard of optimising NVCS is by doing two runs on a dyno, one with the NVCS switched on, one with the NVCS unplugged. Where the lines cross it the best point to switch off.
easy:D
easy:D
This is exactly what i told my mechanic to do when programming/tunning the Wolf 3D. I believe that unless you change internals the optimum point is at the factory setting. This proved true, when tunning my car.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
