  • Replies 181
after not being happy with my cars current tune and performance i too will be taking my car back to the place who did the conversion and wire up.. Gavin Woods Auto Tech...
Should hopefully make use of my new injectors and turbo :P
  • 3 weeks later...
Impressed.
Is all i can say at the moment, I dont think ive ever seen so many props for a workshop/mechanic ever.
I live in brisbane, just got my 94 gtst (will start thread soon to show her off :( ) and shes on 98,000km so i need FULL 100,000 service soon.. ie timing belt, transmission fluid, oil, plugs,some tubes replaced etc
Ide say ill be taking it to this place :)
Anyone have an estimate on how much a full 100,000 service is?
Ive got about $500 to spend at the moment, but still saving :)
I got the 100000km service not long ago with EVERY fluid changed, Spark plugs, timing belt, check other belts, re oil filters. I got mine done in two parts with a few other things checked as well and I'm pretty sure it cost me below $500. But as I said, I got a few other things done as well. I'll try and find the receipts and let you know. Come to think of it I think it was around the $400 mark because I remember having $400 left over from my loan refinance :(
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
