  • Replies 92
PM sent NYTSKY.
Friday is the cut off people. Maybe monday if your lucky :(
Deposit paid.
Getting manifold
Wastegate plumbed straight off the housing of the turbo
And ceramicoating
Hey,
Thats odd... I just text him and he told me low mount is stock location... He will be on here to reply a post soon, just keep an eye out
did you ever find out.
I'm trying to reserve a spot for an rb26 stock position low mount ceramic coated manifold.
but not having any luck raising anyone, just for the record. If I can get a PM confirming a spot,
a price, and how/who to pay I'd pay.
Does anyone know if you can run the standard intercooler pipes with the rb25 low mount setup
Also with the low mount/external gate setup, where abouts does the external gate usually go
Mike.
Hi All,
Sorry for my late reply, I flew to sydney for the weekend to help my sister move.
To answer some questions:
1: I cannot do stock position low mount manifolds for RB20/25. There is simply NO room for a manifold, if anyone has ever back to back tested those cheap stainless manifolds, they actually spool later and make same or less power in my experience. I have seen this on 2 cars, one with standard hiflow, the other GT35. The problem is room, the turbo points straight at the engine, and is about 2" from the head face. Just not doable to any decent standard. Sorry:(
2: My RB26 low mount manifolds are standard position, I have done many of them, and never had a single car have "surge issues" without a balance pipe. I don't have time to go into massive detail right now about it, but there is absolutely no need for a balance pipe. If anything, its the worst thing you could do for spool and HP. Think of a divided manifold and turbo, your trying to use pulse tuning by keeping the gasses divided all the way to the turbo, similarly to a twin turbo on a 6, front 3 runners go to one turbo, the back 3 to the other. Running a balance pipe would be like drilling a hole clean thru the divider in the split manifold. Compressor surge happens when the turbo's are trying to flow more air into the engine than it can consume at that RPM and load point. So how the hell is running a balance pipe between 2 manifolds suddenly going to make the engine flow more air so it no longer compressor surges?? It can't, and won't, and if anything, IMO would actually make it worse due to poorer pulse tuning.
If anyone has back to back tested them and found the opposite, I'd love to hear from you. Otherwise my point remains. Another thing is that the other manufacturers don't use merge collectors. While you might think they look all neat and free flowing, we did a manifold for Rob Baraks Evo3, which had a VERY similar design manifold to those low mount 26 manifolds, and by changing to my manifold, picked up 380rpm of spool (huge) and 31kw at all 4. The air hits the turbine so efficiently and with such velocity with a merge collector that I would find it hard for the air from one turbo to effect the other.
3: All my manifolds are designed to suit 3 litre bottom ends. Regardless of what you order, be it RB20 or 25, it will still sit low enough that if you went to a 3 litre bottom end you would have ample bonnet clearance. I own a R32 skyline myself with a 26/30 in it and this was used to jig up most manifolds. We can fit anything from a T28 all the way up to a GT55 under the bonnet, with anything in between.
If anyone has any specific questions, please email me directly at [email protected], and I will reply in more detail there. Please make your order here with Leon tho as I appreciate his efforts to start and run the group buy and taking one payment from him for all goods will make life a lot easier.
Kind regards,
Kyle
6boost.com
0410 730 598
Edited by 6BOOST
Forget balance pipes, guys, and whatever you do, don't compare a properly designed merge-collector manifold to a chinese P.O.S. in stainless.
If you need to know what a poorly designed manifold can do to your engine, ask me to send you through the bill for my engine rebuild.
And everybody in the group buy needs to tell me what turbo and gate they are running, not just high/external, as I could build everything from a T28 high mount with a 38mm gate for a RB26 up to a GT55 high mount with 60mm gate. So please give Leon details of what flange/turbo you want to run and what size gate. I recommend minimum 44mm and if you haven't purchased a gate yet, the new turbosmart 50mm. If you need gates with manifold contact Leon about arranging one with your manifold from me at cost price.
Regards.........................6BOOST
Thanks Kyle for that info. Again here is the bank details.... Ill send out a group PM to everyone who was already put down a deposit and another one to the fellows who are waiting on answers, just to let you know that kyle is now available to help, as im just a customer not a manifold expert :P
If interested full payment is needed by FRIDAY so i can get the moneys off to kyle to get there babies ordered
National Australia Bank
Acc Name: Leon Minic
BSB: 084-792
Acc Number 79-164-3300
I'm out, sorry.
Stock position would be nice (and cheap), but just out of interest, how much would a custom dump and front pipe be?
Cheers
-Reece
I'm out, sorry.
Cheers
-Reece
Could possible still use standard dump just might need custom front pipe. But may also need to modify cooler hoses and intake pipe. Maximum $500 from my local mechanic... dont know about yours though
Kyle, a few questions
1) What is the largest turbo you can run for a low mount RB25/30? im not worried about keeping factory location, only want low mount.
2) I run a 3L bottom end, but the block wasnt ground flat on the exhaust side where it bolts to the head, so my standard manifold fouled (ended up having to grind 5-10mm off the flange) Will your manifolds bolt up without any problems?
Edited by MintR33
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
