Hi guys my i just bought this 1995 R33 GTST skyline, With 49000kms on the clock but the only problem is it auto which im about to put a stage 3 shift kit in it. It has 17x8 Japanese version Sparco ultra light weight rims on it, it only has one mark in the interior and the engine bay and boot are awesome, I know the purchase price was steep $11,500 on road just from japan. I just purchased this car from Power Road Car Sales in Dandenong, Let me know what you guys think :(.
http://s136.photobucket.com/albums/q192/howie_au_2000/ - my photos
http://i136.photobucket.com/albums/q192/ho...00/12577536.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577539.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577542.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577544.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577547.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577556.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577560.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577567.jpg
http://i136.photobucket.com/albums/q192/ho...00/12577682.jpg
Thanks Guys
Cheers Rob
https://www.sau.com.au/forums/topic/246687-my-1995-r33-gtst/
Hi guys my i just bought this 1995 R33 GTST skyline, With 49000kms on the clock but the only problem is it auto which im about to put a stage 3 shift kit in it. It has 17x8 Japanese version Sparco ultra light weight rims on it, it only has one mark in the interior and the engine bay and boot are awesome, I know the purchase price was steep $11,500 on road just from japan. I just purchased this car from Power Road Car Sales in Dandenong, Let me know what you guys think :( .
Thanks Guys
Cheers Rob
Any Non Major Mod Advice Will Be Greatly Appreciated. :(
Yeah, Im Going to get a hand made 3inch mandrel bent from turbo for $900 shortly havent worked out the muffler i want yet, And ram pod it with a apexi boost controller for a start i just dont want to serious internal mods yet, To people like me i like stuff left stock but if you are going to change stuff make sure you can change it back if need be IE: exhaust, intake etc
cheers man :(
Thanks , I had to pay a bit more for the low kms but overall im very happy with it, I took it home last thursday and cut and polished it after these photos (these photos are of the car on car sales before i bought it) I have a 12 megapixel camera i will upload some better pics of my own this weekend. What size is the stock BOV adapter because im looking at after market ones? and also are the GreedyTrust Profec B Boost controllers any good.
Does any one Know the Value of these mags ( Sparco Japanese Ultra light weight Crimson 17x8 mags - Electroplated edges) maybe thinking about upgrading, What do you guys think
Edited by HoWiE_Au
decent price IMO, looks clean.
Stage-2 kit from Knox Automatics in Rowville, 395installed, highly reccomend :P
good shocks(and springs), tyres, pads, rotors, some new bushes etc, swaybars... those would be my first mods, then go for power
Enjoy!
cheers ryan ill look into that place, Im going to find the time this weekend and try to have a look at the suspension setup in it, it still has Hicas in it . Does anyone know the brand of the front adjustable engine strut brace its got a silver skyline sticker and says manufactured my ibb or something i will verify that tommorow
Yeah shanes good mate i will probably be purchasing another skyline of him in the future. As for the sunroof its a optional genuine nissan sunroof which is great i might tint it tho due to the sunburn i got driving it home :huh: . Im trying to find if my tacho has a fault , or it might be just the auto and the boost kicking into the turbo. The Tacho from 2400rpm to 2500rpm goes down not up for a second , So it goes to 2500 then 2300 then up again is this normal or is it just me lol
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
