Hi guys.
I'm selling all the bits off my 205rwkw R32 GTS-T as a whole package because i want to make my car stock again. I'm doing this to get out of debt, as i paid for all these mods with credit cards. Yes, I'm an idiot. Fun wile it lasted though!
For the price of $8600 you'll get
-Garret gt3071r good condition
-Dr.Drift standard ECU remap
-standard air box with k&n filter (modified to suit Z32 AF meter)
-Z32 airflow meter
-4" mandrel bend intake pipe
-RB26 standard intercooler and piping to suit
-bosch 040 fuel pump (internally mounted)
-440cc injectors
-38mm external wastegate, plumbed back
-3" dump + front pipe (i kept the standard cat back to keep it a bit quieter- full 3" can be arranged)
-Oil catch can
-braided stainless oil and water lines
-Adjustable cam gears
-splitfire coil packs
-excedy 5 puck clutch (strong yet street friendly)
-greddy EBC profec II
More stuff that i cant think of :)
All of these things cost me well over $9000 for the parts only.
It would take 1 weekend, maybe 2 for me to put all the mods onto your car.
I have dyno sheets to prove.
The mods are still in the current car, and I'd be happy to take you for a spin.
I will set the cam gears to suit your engine on a dyno.
This will include a dyno printout.
RB20's are capable of handling more power, and all the mods could easily support more power, all it would take to get 230rwkw would be more tuning at DR.drift which i would be more than happy to organise.
ANY (and i mean ANY) more modifications that you would like I can do at a decent price.
ONLY CONDITION OF SALE: As i want to make my car stock again, and i don't have any stock parts i would require to keep all the standard items that i remove from your car.
CONTACT DETAILS: my name is James. I'm located on the Mornington peninsula. My phone number is 0423 043
Call, sms or pm me anytime.
Thanks.
https://www.sau.com.au/forums/topic/246847-205-rwkw-r32-gtst-package/
should be able to make way more power than that out of those mods man...
i made 205rw kw on my rb20det with just fmic, full exhaust, gtr fuel pump and 480hp turbo, stock ecu, stock injectors..
well yeah, it has the potential to support alot more power, but A- ive got stock internals so i wouldnt push it past the 230rwkw mark, and B- when i got it tuned, Sam (aka dr.drift) didnt want to turn up the boost any more until i put new head bolts in. apparently he's seen heads lift off the gasket from high boost on old head bolts
and no, at this stage I'm not willing to seperate.
cheers. James.
So $8600 gets you those mods but an extra $1400 gets you the car and engine aswell? - http://www.skylinesaustralia.com/forums/vi...ts-t206318.html
Edited by Bennett
bahah, someone buy the parts and i'll take whatevers left of the car for $1400 then :banana:
rice me up- like its not a bad setup but man to tell you the truth your kind of dreaming for that kind of figure your asking mate, that price can probably get you 260+rwkw, i think around 5k installed is pretty good as its all second hand stuff aswell
cheers tony
cheers. James.
this dr drift always seems to have an excuse when his tunes don't make power... which is pretty often i've noticed
cheers. James.
how much boost are you using to get 205rkw? and how much do you think the rb20 can take before the heads start lifting?
you must be talking +25psi???
nah, it only needs 16 pounds to get 205. no idea what it would take to lift the head.
Christ I'm getting burned...
In my defense: admittedly it's not a massive power figure, but if you were to put all that equipment on an engine with forgies etc, you'd be able to get heaps more power. id say over the 300rwkw mark maybe? couldnt work it out exactly.
  • 1 month later...
To clarify it the head had been off the car, and was put back on re-using original stretched head bolts. On every single occasion I've seen head bolts re-used they have stretched more and blown head gaskets.
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
