I really enjoyed watching stage 3
Stage 6 though.....hmm. Not so good to watch.
Hope the next event goes a little smoother for you.
cheers
btw are you running stock brakes!?!
For the next event I'll be using a different mind set I think. Won't be looking at the stage times therefore won't be trying to catch the guys in front of us. Especically when it's the RGM R35 :P
The brakes are still stock except for Blitz pads which I find to be excelent and some unknown brand cross drilled rotors. We suffered very little fade during the stages although when we got to the end they were fairly smoking. Only drama was, and still is to some extent was a bit of pad knock off so the pedal wasn't always picking up in the same spot.
Edited by Evocoop
  • Replies 170
car was going great mate. sad to see the little off you had, but that's tarmac rallying for you and bound to happen from time to time. up till then it looked great but like you said definitely not hooked up nicely in the rear. possibly time to get some shocks with a bit more oil capacity (remote canister time) but as always it's just more $$$. they really get a hammering on road tarmac rally stuff so I can see why you might think they were overheating.
Yeah I'll try to get something better in there sooner or later. The first runs on both days were fine befor the heat set into the shock oil so fairly sure that was the problem with them.
I just finished off the new fuel set up. I've put 2 x 044s in there now with dash 6 braided lines to each end of the rail. We were having a bit of trouble on the dyno with some inconsistant AFRs and i wasn't holding much hope for the old SX performance pump. So tryed and tested 044s were the go.
  • 2 months later...
Nice build up evocoop...
shame to see it get damaged,but good to see your up and going again..love the midnight purple btw.
Cheers Mate. I always wanted a midnight purple r33 back when I was a youngin.
I bought a cusco front sway bar a few days ago. Seems better but I had to lower the mounting position on the crossmember to clear the oil pump as the bigger diameter sway bar was fouling on it. Not sure if this will affect the performance of the sway bar but it had to happen and still feels better than standard? Anyone any experience with sway bar phisics???
  • 1 year later...
Well it's been a while since I posted any updates on my dunger. It's not for lack of interest rather the fact that I am truely discovering the meaning of time poor.
I've been a bit steady on the build of late but have made a few changes since the last post. I bought a set of Greddy coilovers when we traveled down to superlap in may and some adjustable rear lower control arms and a hicas removal set up using s15 toe rods. So I've been playing around with wheel alignments but more recently doing some smash repair and re designed my fuel set up. So here's a couple of pics of what's been going on over the last year or so.
All ready for the tarmac sprint back in june. This pic was taken on the Reid Park V8 super car track which we used part of for the rally sprint.
I crashed in that event again. I got a bit carried away trying to keep up with Marlin and side swiped a cutting and backed it into some armco. But thats rallying.
I dug out some parts to get me through to the end of the sprint season up here and gave it a bit of love with a 4 pound hammer and a piece of railway iron for a dolly to make it roughly the same shape as it was. I also destroyed to wheels so I aquired a set of 18 inch RPF1s. This pic is showin them fitted up and the new rear bar zip tied on.
Had some sunoco race fuel given to me so we decided to chuck some in, tuned it up and went to the strip for something different. We made 436rwKW and ran a 10.71 @ 132mph with a set of r888 toyos and still with the circuit wheel alignment then broke the 3rd/4th selector fork being ham fisted.
I got my panel beater mate to stitch on a new back half of an old quarter panel from an old front end wreck.
I had my first go at trying to blend clear coats when I painted the new quarter. I blended it through the piller and I was really happy with my first ever attempt. This pic was straight off the gun but once I had wet rubbed it and buffed you can't even tell it's been blended. Beginners luck at it's best.
Finally I've changed the fuel system around a bit with the hope of running E85 this year some time. Basicly a 40 ltr procomp baffeled fuel cell into a carter lift pump under the new plate alloy floor up to the old surge tank and then into 2 O44s. made custom tank mounts that hang from the chassis rails. Pretty much finished that off last weekend.
That's it pretty much up to date for anybody interested. Our first hill climb is this weekend so pretty keen to get the year underway defending the hill climb series and also the sprint series that we won last year. I've got a Nismo diff coming and will be giving the Atessa a freshin up soon to. I installed a mechanical pressure guage into the line yesterday so I can see if it's working effeciently.
nice progress mate. yeah the RPF1s are hot. very reminiscent of the wheels enkei make for various F1 teams. I guess that's why they call them RPF1s.....
E85 is a great idea. cheap fuel and good power. exactly what you want for a track car.
I'm Going to start fitting 2 new diffs today. Link had a special on front and rear diffs so I got a Nismo 1.5 GT LSD Pro and a Nismo 1 way for the front. Big weekend in the shed. Also pulling the 4wd pump out and replacing it with one that has lower KMs and a good clean. Best I get started.
AMAZING car man. How are you liking the gtrs's? do you find them laggy at all? What suction pipes are you running. Im trying to source some ATM and do not know which ones to go for?
x2
How do you find the GTRS's for tarmac work?
Cheers
Justin
The Gtr-s are a 700ps kit so a little smaller than drag guys are running. For what we do up in townsville, like doing sprints on a go kart track they are probably a little too big but hopefully the will start to work when I start road tripping down south with it. But in saying that, if it lags up I just clutch kick it. :rofl2: They also have shocking reversion when rolling on from low rpm and played alsolute havic with the AFM but since changing over to a d-jetro the reversion doesn't effect the AFRs so it makes it less annoying.
The suction kit is Greddy with HKS filters and greddy hot side piping.
Couple of things I've been up to over the past week. I got the diffs done and all is good. definatly notice the front is now LSD. Will probably need to be aware of it on the track. Good though. While out testing the diffs out the clutch spun. Probably too much grip for it. So the gearbox is now out and the clutch is on it's way to Direct Clutch Services for a rebuild. hopefully have it all back togethern for our first sprint round next weekend. Also the new rotors turned up and I've dummy mounted them up to the custom hats. They are V8 supercar spec Alcons.
Some pics
Stock rotor beside the new rotor from PWR
Dummyed up in the my wheels.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
