i got one for all of you out there on the way to fleet sa to pic up a company and seen a VW T5 CAPMER with flashing red and blue lights in the back window wen i got up closer it was 2 cops giving a lady a ticket so wot im trying to say is if your out on the road be careful there going to extreme lenths to bust anyone they can............................how fcked is that a VW T5 CAMPER VAN W..T..F
lol thats awesome.
Another one to watch out for are the un-marked bikes too !
there are so many unmarked cop cars rolling around its not funny
i have seen previously Land Crusiers with cops in it
They're Star Force officers. Zero tolerance. Don't go messing with them :D
^^^ i think they were star force
it was funny i was sitting at the lights and they were next to me once
4 of them in there and they were all looking at the line......
i was like ohh wtf 4 cops in the one cruiser
Seen them down Rundle St for a few nights in a row, getting the stupid cab drivers to stop congesting the street. They were plenty hard on them.
Not that I mind, I hate cabbies.
watch out for
unmarked ve's
blue and white unmarked bmw bikes
a blue and black xr8
a red vz ute
white vw and hiace vans - these guys are either rbt or dedicated defect bus... stay away
silver and black land cruisers with heavy duty racks on top + spot lights mounted at all 4 corners
thats all from my sightseeing over the last year or so that i can remember
They're Star Force officers. Zero tolerance. Don't go messing with them :P
definitely Starrys or drug squad.
couple of mates of mine are starrys, Zouma & Pacey (real names withheld) and you are correct in saying not to mess with them.
if they stop you car for any reason, they'll have you out of the driver's side window before you have time to touch the door handle......even if your window is wound up, lol
EDIT: Anyway, this is a Defect Thread, so everyone back OT (me included, lol) :D
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
