he aint been a cop for long, but he's been round the car scene for longer than you've had cooked dinners my friend ;0
you gotta work on your banter a little bit matty, wrong expression me thinks. or just worded poorly. either or.
What? No one cooks their dinners? :cool:
I know where Matty's coming from. :banana: Hey Matty, I might know this Ryan cop, wouldn't happen to have a brother named Aaron? PM me and I can give you a last name. Haven't seen these guys in years ... oh the trouble we got into :)
brain dead day that day dave
ruby, dont know if he has a brother lol, only met him a couple of times through other mates. most people would probably know the zero traxion dvds..............and where they were filmed (and who was in them LOL).
and rocky, he's registered on here as well, think you were thinking of the username 5LEEPER
finally got my car on the road after 11 months. driven it for 1.5 weeks when i got pulled over on regency rd sat morning. the cop measured the height of the car and said it was 5mm to low and that the wheels were sticking out the guards, After looking around the car and under the bonnet he asked me if i wanted to go to regency. when i replied not really he said that driving the car around like this
is basically driving around with a big flag on top of the car which said defect me. i said i couldn't see the flag just joking with him as he checked my license and then told me to have a nice day and drove off without defecting me. what a tripper, i thought i was off the road for sure.
Very, very lucky! If you get a chance mate, call me tomorrow to discuss the motor, I'm very interested
yeh u can get his last name off pretty much any zero traxion clip, i wont post it up here as its not my place, but a quick search will reveal it if need be. also a bloke on here who's in the force, not sure if he's a full cop or not, but he's moved on to ford and sold his 33 as apparently they have no issues defecting the newbies cars when they come lol
:D:):ninja::)
Kudos to the cop....sounds like he was a nice chap....but to be honest mate you were so damn lucky....now go and buy a lottery ticket and really put that flag on the car
Not defected but Im taking a 32 with a 25det in it through regency as it is from Victoria, with the brake upgrade will 33 slotted rotors and callipers on the front be enough? Or do I need to replace the rear brakes as well? and if so how much should I expect to pay for the callipers, I will be buying the rotors separately brand new.
Cheers.
Cheers.
you should be fine with just the front brakes dude. afaik theres no difference with the rears.
Ok well here's the whole deal I am buying this car from VIC on Sunday and it is not engineered or registered with the RB25. http://www.skylinesaustralia.com/forums/Eo...ts-t285533.html
Now he is supplying me with 4 stock rims, afm and stock cooler + piping. I can get a stock ECU, entire intake with injectors, fuel rail and fuel pressure regulator off a mate. I can easily remove the catch can, turbo timer and replace any bushes, the suspension is non adjustable and is above 100mm in ALL places. I can also get an EPA test done that will pass and the exhaust is apparently very quiet, also the pod is mounted to the chassis.
Now I know I am going to have to replace the intake and fuelling accessories, the ECU, put the stock AFM back, remove the vented catch can and turbo timer but can I get away the front mount and the suspension? Is it even possible to pass with the ECU providing it passes the EPA test with it installed? It is plug and play so no fuss replacing it but would make it easier if I could leave the ecu + the fueling system in place as this will be the biggest pain in the ass.
Oh also the engine numbers will obviously not match up as the car is still registered with the RB20, providing they check that the car has the R33 turbo brakes and it passes the inspection will they give me authorisation to get it registered?
Anyway thanks guys, wish me luck. I've got 2 months of rego left on it so I will just drive it around on VIC plates until I get all these things sorted.
:banana:
Edited by Rolls
If the car is stock is there anything else I need to do to the car to make it pass?
im half way doin the rb25 to my 32 and i was under the inpression u have to get a emisssions test? just to make sure the stock ecu is there and un modified. thats what i was told and told, and it dosent matter about the rear r32 brakes being almost the same as the r33 brakes, u must have the r33 brakes or the same year or above brakes when doing the engine conversion. This has been what i was told by my mechanic. and it might pay to make sure the slotted rotors are ADR approved. i dont think all of them are. good luck with it though, i gotta take mine through soon :domokun:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
