for anyone thats interested, i just printed something off dtei that says as of the 1st of jan, 35% tint will be legal on windows except the windscreen (obviously).
very interested brew
might even motivate me to get my tinting redone later 2010... was not happy with the shit job tintacar did
-D
What % is currently legal?
In SA...0%, your not meant to have any on the front windows, but you can go as dark as you want behind the driver. Well that what i was told by the guy who did my window tinting.
The Road Traffic Rules 1999 set the standards required for window tinting on motor vehicles in SA.
Windscreens - must have a luminous transmittance of at least 75% for vehicles built after 1971 (70% for others) and cannot be coated in a way that reduces the luminous transmittance in any part of the area below - either the top of the windscreen wiper's sweep or the top 10% of the windscreen whichever is lesser.
Driver and front passengers windows - These windows must have a luminous transmittance of at least 70%
Windows behind the drivers seat - These must have a luminous transmittance of at least 35%.
All windows must not have a reflectance value of more than 10%.
SA Transport - Window Tinting Laws
That is so bloody awesome - I'd heard rumours of this coming in, but it's good to see it's a definite.
I can finally get my R34 fronts darker than factory (and maybe closer to matching the factory privacy glass rears).
Woot Woot Woot! *happy*
+1 :cheers::santa:
Just gave Auto Perfection a ring, R34's with no current tint on the front passenger windows, in 35%, costs around $110, not including SAUSA discount :) i know what ill be doing soon! They re-open on 4th Jan.
hey guys just went through the pits not long ago and talkad about tint to the guy. 75% front and 35% rear is legal in sa. 75%'s f**k all and not even worth bothering with. my s2 stageas come standard with 75% front and somethin stupid like 14% rear but cos its built in and factory item theres fark all they can do.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
