for anyone thats interested, i just printed something off dtei that says as of the 1st of jan, 35% tint will be legal on windows except the windscreen (obviously).
very interested brew
might even motivate me to get my tinting redone later 2010... was not happy with the shit job tintacar did
-D
What % is currently legal?
In SA...0%, your not meant to have any on the front windows, but you can go as dark as you want behind the driver. Well that what i was told by the guy who did my window tinting.
The Road Traffic Rules 1999 set the standards required for window tinting on motor vehicles in SA.
Windscreens - must have a luminous transmittance of at least 75% for vehicles built after 1971 (70% for others) and cannot be coated in a way that reduces the luminous transmittance in any part of the area below - either the top of the windscreen wiper's sweep or the top 10% of the windscreen whichever is lesser.
Driver and front passengers windows - These windows must have a luminous transmittance of at least 70%
Windows behind the drivers seat - These must have a luminous transmittance of at least 35%.
All windows must not have a reflectance value of more than 10%.
SA Transport - Window Tinting Laws
That is so bloody awesome - I'd heard rumours of this coming in, but it's good to see it's a definite.
I can finally get my R34 fronts darker than factory (and maybe closer to matching the factory privacy glass rears).
Woot Woot Woot! *happy*
+1 :cheers::santa:
Just gave Auto Perfection a ring, R34's with no current tint on the front passenger windows, in 35%, costs around $110, not including SAUSA discount :) i know what ill be doing soon! They re-open on 4th Jan.
hey guys just went through the pits not long ago and talkad about tint to the guy. 75% front and 35% rear is legal in sa. 75%'s f**k all and not even worth bothering with. my s2 stageas come standard with 75% front and somethin stupid like 14% rear but cos its built in and factory item theres fark all they can do.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
