wow.... so what can you do from here??
obviously you have proof that the key was in one piece on arrival!!
i can see this going on for a while
+1
Thats just wrong.
Wow the f**k can you accidentally break a key in half? :D
****HERE TO HELP*****
If anyone is after a set of 4 standard wheels with brand new tires for regency send me a PM on here or contact me on the mobile 0432 581 798.
-lewis
That is very kind of you Volk, ill defiantly keep you in mind if i get defected. Thanks again.
i was done on the night i got my skyline( with my p plates) was done at the bay for fog lights my turbo timer and boost gauge where nicely lite up blue and clearly visable and the cop even looked at it but decided to give me a warning. not saying anything about the mysterious blue light, i was amazed once they left i noticed they parked about 50meters away asif waiting for me
all in all very lucky
Just got out of Regency - went by quite nicely I must say. The guy wasnt too thorough and was quite friendly. Even had a couple other inspectors pop over to checks out the GTR and even asked a few questions... one of them about the baseball bat in the back seat which is a steering wheel lock in the shape of one lol
Failed for R/H and L/H front top control arm bushes - understandable, the wheels wobbled like they were going to fall off haha
steering back boot split - easy fix
No defect issued and only the failed items will be re-checked.
Hopefully Boostworx comes through with the goods tomorrow as they said so I can fit them up for my re-inspection on Friday!
If not Auto Parts Professionals can get them in that day for you. They got front upper inner and outer nolathane R32 GTS-T bushes in that day when I called up, took about 4 hours for them to get delivered, not to mention they were cheaper than anyone else I called.
They are on main north road next door to city dismantlers and their number is 8260 2044
Had the re-inspection today... passed but this inspector discovered a couple things the previous inspector didnt but because it is a re-inspection he couldnt add more things to the list to send me away again so he passed me. I replaced the bushings on the upper control arm as told but there was still play in the front driver's side and it was coming from the knuckle ball joint thing... and it had un-tagged braided brake lines(non-ADR approved).
That was good of them to not make you come back. I've heard stories of being going back 3-4x
I had a similar issue where they noticed play in the wheel, put it down as wheel bearings but it was in fact hicas arms, was lucky the mechanic picked it up.
Had my car defected tonight at the new Gepps Cross Shopping Centre, was a car cruise, was doing nothing silly, cops swarmed in and went over everyones cars. I got done for a Boost controller unit that isn't even plumbed up/connected or anything, exhuast too loud, exhaust flap silencer, ride height 20mm under legal height on rear, front was ok, coilover suspension, pod filter. Total $681 fine, but because i have the car registered with 2 names between me and another member in my family as joint drivers, the officer tells me they will also receive a $681 fine. Thats rediculous i say. So here it goes to get the car ready to go through regency, anyone got anyways to help me out. Much appreciated
$681!!! what the f**k since when is getting defected a fine able offence?
Im dumbfounded. I would fight this in the court. Theres no way they can make two people pay the same price for the one minor offence.
-D
WOW You got reemed pretty good! What cruise was it? RCK? Anyone doing burnouts on the cruise? Someone must of reported to the Police about burnouts or something for them to raid the place and defect you like that...
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
