Hey Guys,
Just a heads up... I think the boys in blue are doing a crack down as we speak as i have noticed alot of defect stations over the past 2 weeks especially down south near Seaford...
PLUS: when you get pulled over at a defect station on the side of the road, do they pop your bonnet??? I was deffected about a year ago, and they booked me for ride hight and they didn't pop my bonnet but i was thinking as my car is nice and stock on the out side appart from mags and front bar, weather they would pop my bonnet and look for other things???
Cheers
Jamie
Ive been through 5 times and never had to put a stock exhaust system back on.
Last time I went thru I thought it was kinda loud. Turned out fine.
Turbo timer not just disconnected but fully removed.
It's illegal to have a turbo timer installed? How come i can pass a roadworthy with it connected though?
Hey Guys,
Cheers
Jamie
Never mind...
Car is completely stock engine wise...
However, is it illegal to have a front strut brace or a boost gauge mounted just on top of the air vent of the drivers side???
Cheers for your help :worship:
Strut brace fine. Boost gauge no
Depends where the boost gauge is, if its in a vent or down below the dash it is fine, on the dash or a pillar you can't have it though.
Turbo timer is illegal because if you have a crash and the car get a fuel leak and it keeps running, sup massive fire. They shouldn't have given you roadworthy with it connected.
wow didnt know lol thx i went to 3 different mechanics to.. and not 1 picked up on it lol.. guess im lucky then
Edited by nismo07
hey guys i want 2 vehicle identit inspections at lonsdale inspection station i want 2 get my car pass for it 2 be in SA rego because it was from NSW so all the numbers line up so all that pass but they defected me for fibre glass vented bonnet and adjustable coilovers and boost controller.. when
i go back there can they pick on anything other and what they said 2 me to fix ? thanks
Edited by MAD R33
what did you expect lol...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
