just want to know what people are using for suspension when they go through for an inspection?
20 year old std suspension is well gone, and im not paying $200 for a set that might pass or leak, so whats the deal these days? Would they allow a set of Bilsteins pass at legal height? They arnt adjustable like the normal "screw up and down" type like you normally see, just a circlip adjustment.
friend of mine has passed regency with that style strut many times.
I am assuming you are after a set to suit a 32??
yerp
I would assume they would let these through, as the only adjustment is via a circlip, which if there is only one groove means no other adjustments.
If they are adjustable below legal height they shouldn't pass, however they might pass them if it isn't obvious that they are adjustable.
Or if the height is reasonable they might not even look.
Edited by Rolls
Depends where the boost gauge is, if its in a vent or down below the dash it is fine, on the dash or a pillar you can't have it though.
Turbo timer is illegal because if you have a crash and the car get a fuel leak and it keeps running, sup massive fire. They shouldn't have given you roadworthy with it connected.
See i've never got that rule/law, as in heavy trucks they ALL come with turbo timer's standard and keep running even if you turn the maxi's off...
Someone explained it here years ago i think, but trucks are a different kettle of fish, being much larger motors running huge turbos that are running max pressure towing loads all the time. They need the time to help cool the turbos down, unlike cars chugging along at a regular 60km/h pulling 2.5krpms per gear change.
Diesel engines have mechanical fuel pumps, if the engine stalls the engine stops pumping fuel, if there is a fuel leak then the engine will almost certainly stall due to the MASSIVE pressure the lines are under, but being metal lines they almost certainly wouldn't leak.
So basically you have an accident in a truck as soon as there is a fuel leak that could cause a fire the engine basically stalls anyway, hence stopping the fuel pumping into the fire. In a petrol engine if they crash and stall the electric pump will keep pumping regardless.
Also diesel isn't as flammable as petrol.
Edited by Rolls
So i'm looking at buying 'Longz' R34 GTR from NSW, from my understanding it'll need to get an identity check which does involve some pit checks.
It has the following:
"* Apexi Power FC with Commander ($1600)
* HKS Boost Controller ( $800 )
* Z-Tune Carbon Fibre Bonnet with Carbon Fibre Aero flush pins fitted. ( $850+300 )
*Apexi Pen Turbo Timer ( $100 )
* Tomei Cam Pulleys ( $520 )
* Ganador Titanium Exhaust
* Nitto Clear Cam Cover ( $120 )
* BC Coilovers fitted 2500km ago $1300 have reciept"
What would i need to change back to stock? I'm guessing a lot of it......
This vehicle identity check, can i get this done anywhere else besides regency/lonsdale?
Edited by occxlr8ed
Any police station will do it, but if they suspect it is modded it will be sent to regency, If so the following will need to be returned to standard:
Turbo timer - removed
cam pulleys if visible removed
exhaust if above legal limit removed
coilovers almost certainly will need to be removed for both pits and regency as they will be adjustable and too low
bonnet 100% needs to be removed as it doesn't pass ADRs
Boost controller removed
Power FC removed and stock ecu installed
depends on the rim size but if they exceed the ADRs also returned to stock
my advice is wind the coilovers as high as possible, buy a set of stock rims and remove all fancy things, also put a non clear timing cover on, that should make it look stock, oh and obviously take the stupid CF bonnet off haha that will be instant ass f**king
Edited by Rolls
freaking attention that skylines get!!!
the past 2 years of driving my 350z, lowered to about 4cm of ground clearence, etc. etc. i've had ZERO problem, not one cop pull me over....
if you get a defect sticker is it the same deal? i've had my mates get theirs cleared at a cop station instead of regency however that was just for tint and the other case headlights.
Edited by occxlr8ed
Ive never been defected driving on the roads, but I have almost been defected quite a few times, mainly due to doing stupid stuff and just getting out of it.
Minor defect is police station eg what you just mentioned, major defect (suspension, too loud, turbo etc) is regency.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
