^^ Danny with age like that on your side you may need to retire and mod down to a RB25DE hahaha
The elderly and turbos do not mix unless attached to a 2.5L Diesel towing a caravan ;)
On another note when is the next wreck coming in???
  • 2 months later...
I got defected by a wanka cop for bov, blue parker lights and low beam turning off when high beam is on which is factory stock not a wiring problem he also thought the turbo timer was a boost contoller! the cop then said i have a week to take it to regency! I explained i only just bought the car 3 dsys ago and was gonna change the stuff! I asked why i couldn't take it to a cop to get the deffect off! He said caus there not mechanics they don't kbow what there looking at! I asked if he was a mechanic he said no then i said well how do you know what your looking at! He then ssid get smart with me ill arrest you an fine you 500 for driving a deffecable car i said you can't do that!
turbo timers are an instant defect, illegal on sports cars and they're a waste of money. well they can fine you $150 dollars for each defect they find. there is no set time frame you have to "get it to regancy" even if it runs out of rego just get a day permit.
To the guys out there that run a greddy intake manifold, have you even been defected for it? Or can you get defected for it??
Cheers
Get an idle emissions test and send in an application to modify your vehicle, they will come back saying you need an emissions test, once you have that you can go to regency to have it inspected and then you will get a nice piece of paper to put in your glove box saying you are A-Ok, if not then you are up to the mercy of the cop.
Actually even with the piece of paper you are up to the mercy of the cop.
You can get defected for your exhaust not looking standard, you can get defected for things that do no even physically exist on your car so if they want to defect you, they will.
Basically if you draw the wrong sort of attention, guaranteed defect no matter the condition of your car.
Edited by Rolls
Just play the game as best you can and don't drive like a dickhead and more often than not you will be fine. I got an application to modify my car with all my mods listed, idle emissions test and keep the inspection record in my glovebox, if your car looks stock, you show them this and don't act like a twat you'll be fine the majority of the time,
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
