V8 v R33 GTR
102 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
hi i do under stand that this is a skyline website and i my self have a skyline and it is my pride and joy
but just putting a hypothetical out there lets say that u were offered a R33 GTR for free stock and no strings attached
but then the person giving u the car says that for free they will put a V8 like the ford aluminum 4.8L DOHC or GM small block that is similar u get the idea
would u keep it stock or will u get the V8
this is my first poll so soz if i stuffed it up
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/
  • Replies 60
Your saying that someone would actually swap the legendary rb26 for a GM or ford v8? does that include the 7litre ls engine they put in the corvette?
The new zr1 engine puts out 600+ hp so that wouls be my choice but if its just the crappy 5.7, 4.8litre engines then id rather the stock rb26.
lol stock r33 for sure haha
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4292683
the V8 has to be a small block because in the real world a big block will be real hard to fit in a skyline
ford sell out of the box motors fully dressed with +500hp and it is a small block and good for daly driving
http://www.fordracingparts.com/crateengine/modularcobra.asp
so the small blocks can put out a bit more power then ppl give them credit for
or on the other hand u can go with a RB26 which is still real good
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4292753
If I took the LS2 from my 07 clubby and put it in a 33 gtr, I don't think I would be lacking in smiles when the foot goes down :) No doubt more response everywhere then stock 33 gtr with stock rb26.
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4292785
if still 4wd, then v8. if not, then stock.
what makes you ask this? is it ever going to happen? bit random.... or are you thinkin of putting a V8 in one but too ashamed to admit it?
as a side note, someone up in sydney is building a VH41 (45?) power R32 GTR, still retaining the 4wd, with a couple of turbos thrown in for good measure. i think its performance metalcraft that are doing it..... cant remember now though
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4293788
If the V8 can somehow be adapted to work with the ATESSA then I'd take the V8. Otherwise I'll stick with the RB26 and ATESSA (what good is lots of power without traction?).
fun thats what!
there are millions of r33's out there so do it, be different
some guy on boostcruising put a nissan v8 (not sure of the name of the engine) into his r33 it was doing low 12's from memory
Edited by thorpe84
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4294362
RB26 all the way.
Thats the reason for turbo chargers, don't need all those Cubic Inches IMO.
And whatever top end you can achive with a V8, you can do the same with a 2.6lt Straight 6 Twin Turbo.
Thats how I see it anyway, I enjoy the feeling of the boost kicking and high reving cars.
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4294361
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
