  • Replies 719
Really? Was that on the old website?
Would love to get the go ahead on the Ultima >_<
I vote that at the end each entrant be allowed one lap sideways. Mmmm, wonder who's done that before...
I still can't believe i got in trouble for this, talk about fun police.
It was the most entertaining thing we saw all day... You definitely had the support of the crowd over at iced coffee, but we all knew it was a matter of time until you saw a black flag waved at you :P
Nah Jack the Radical is a great car to drive,,,proberly the best race car Ive ever driven.
My old Capri sports sedan was by far more of a hand full.
Neil.
Out of curiosity what's the best times you've done in both cars Neil???
Nathan, what times did you end up doing? Its an RB25? What sort of grunt and suspension did it have. Looking at getting a feel for what i should be aiming for from a full weight GTSt at Oran Park on street tyres. I figure if i throw on semis then i am a fair chance of getting a similar time :(
Nathan, what times did you end up doing? Its an RB25? What sort of grunt and suspension did it have. Looking at getting a feel for what i should be aiming for from a full weight GTSt at Oran Park on street tyres. I figure if i throw on semis then i am a fair chance of getting a similar time :laugh:
I did a 1.20 with 280rwkw and Federal RS tyres. I'm running an rb26 with a gt3582, retuned it last week on e85 and it made 320rwkw.
According to natsoft you did a 1:21.2...
http://www.natsoft.com.au/cgi-bin/results....07/2008.ORAN.SL
Roy, I say you'd be doing the same times as DRIFTER or maybe quicker with re55's, providing you stay on the black stuff.... :laugh:
nah, I reckon my Supra on road tyres would run 1:21s this year. It did a 1:24.9 last year on Federal 595SS which were hopeless. The Kumho Ecsta XS tyres (180 treadwear) dropped 2.2 sec off Lakeside and 2.5 sec off QR Sprint times. I'd expect closer to 3 sec off Oran Park GP due to its length and the nature of the course. Plus maybe half a second from the slight power increase from the FMIC and FCD and 1 bar. It was stock last year.
Roy's car should have similar power in a much lighter body (Supra is 1640kg with driver & half a tank) and better tyres in Open class. I reckon 18s too.
Roy, I say you'd be doing the same times as DRIFTER or maybe quicker with re55's, providing you stay on the black stuff.... :)
Dam Natsoft get's in the way of a good story.
Well i was back in Melb for 1 week and i got absolutely nothing done on the car. So it will be probably be running in its current state of disrepair rather than with its new bits.
So looks like i will be happy with a 1:20, and stoked with a 1:18. Either way i just hope the car is solid for the long drive back to Melb.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
