  • Replies 719
Really? Was that on the old website?
Would love to get the go ahead on the Ultima >_<
I vote that at the end each entrant be allowed one lap sideways. Mmmm, wonder who's done that before...
I still can't believe i got in trouble for this, talk about fun police.
It was the most entertaining thing we saw all day... You definitely had the support of the crowd over at iced coffee, but we all knew it was a matter of time until you saw a black flag waved at you :P
Nah Jack the Radical is a great car to drive,,,proberly the best race car Ive ever driven.
My old Capri sports sedan was by far more of a hand full.
Neil.
Out of curiosity what's the best times you've done in both cars Neil???
Nathan, what times did you end up doing? Its an RB25? What sort of grunt and suspension did it have. Looking at getting a feel for what i should be aiming for from a full weight GTSt at Oran Park on street tyres. I figure if i throw on semis then i am a fair chance of getting a similar time :(
Nathan, what times did you end up doing? Its an RB25? What sort of grunt and suspension did it have. Looking at getting a feel for what i should be aiming for from a full weight GTSt at Oran Park on street tyres. I figure if i throw on semis then i am a fair chance of getting a similar time :laugh:
I did a 1.20 with 280rwkw and Federal RS tyres. I'm running an rb26 with a gt3582, retuned it last week on e85 and it made 320rwkw.
According to natsoft you did a 1:21.2...
http://www.natsoft.com.au/cgi-bin/results....07/2008.ORAN.SL
Roy, I say you'd be doing the same times as DRIFTER or maybe quicker with re55's, providing you stay on the black stuff.... :laugh:
nah, I reckon my Supra on road tyres would run 1:21s this year. It did a 1:24.9 last year on Federal 595SS which were hopeless. The Kumho Ecsta XS tyres (180 treadwear) dropped 2.2 sec off Lakeside and 2.5 sec off QR Sprint times. I'd expect closer to 3 sec off Oran Park GP due to its length and the nature of the course. Plus maybe half a second from the slight power increase from the FMIC and FCD and 1 bar. It was stock last year.
Roy's car should have similar power in a much lighter body (Supra is 1640kg with driver & half a tank) and better tyres in Open class. I reckon 18s too.
Roy, I say you'd be doing the same times as DRIFTER or maybe quicker with re55's, providing you stay on the black stuff.... :)
Dam Natsoft get's in the way of a good story.
Well i was back in Melb for 1 week and i got absolutely nothing done on the car. So it will be probably be running in its current state of disrepair rather than with its new bits.
So looks like i will be happy with a 1:20, and stoked with a 1:18. Either way i just hope the car is solid for the long drive back to Melb.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
