With a max upper limit of say; $18,000 but a preferable limit of $15,000 what car should I buy? More than happy to spend less too. Some limitations;
Has to be a car not typically viewed by the public (or mainly the police) as a hoon car.
Preferably secondhand.
Reliable.
Non turbo.
No V8s.
Doesn't need to be overly economical, but nothing that guzzles either.
A bit of guts, nothing performance wise, but a bit of zip in traffic.
A nice car - nothing ugly, and something I can take a bit of pride in.
Ones I am considering are; MX5, old BMW (although I hate these cars, so probably not), an old Lexus, Prelude, or convertible Celica.
Thanks for any input.
https://www.sau.com.au/forums/topic/248193-what-car-should-i-buy/
Forget the Lexus. They're gutless without a turbo or a V8. As are non-turbo Celicas. I'd rule out a Type-R as well, as they do get looked upon as hoon cars. I know it's "eye of the beholder" kind of thing, but I haven't seen a Corolla that I liked the look of.
I am quite fond of the last generation Prelude VTiR. I reckon they look really good, and the engine should pull OK. It's bigger than an Integra of the same generation, so it should be a bit more comfortable. Alternatively, an EK Civic VTiR coupe. The hatch looks a bit ghey. If you want some guts, they have to have VTEC.
Alternatively, you could consider a N14 or N15 Pulsar SSS with the SSS badges shaved off. It then just looks like a cooking Pulsar, but the SR20DE in the front has reasonably good torque for its class.
I do like the sound of the Subaru Liberty. They have a boxer engine too?
I'll look into Integras too, although I much prefer the way Preludes look.
I'm quite keen to get a convertible, besides MX5s and Celicas what other cheap models are avaliable?
No Commodores, I know they're all over the road but P plates + Commodore = hoon. Plus I just dislike them.
Ill get flamed for this but only saying it because i own one.
Get the latest model Proton. Looks are ok but the main reason is reliability and economy.
The things never have any problems if looked after and the fuel economy can only be compared to a Prius!
Im currently getting 600kms out of a 40l tank.
Thats 6.6L/100km!!!
Yeah the liberty is a boxer engine 2.0 or 2.5ltrs
Safe, reliable, good value....shit I should get myself one.
Vehicle 2001 SUBARU LIBERTY 3GEN MY02 RX
Price $17,999 *
Kilometres 58,740
Body 4 door 5 seat WAGON
Colour SILVER
Transmission 5 speed Manual
Drive type 4WD
Engine 4 cylinder Unleaded Multi-point injected 2.5L (2457cc)
Reg Plate AJ99MJ
VIN JF1BH9KJ41G031950
Stock # MCS82
Comments 1 OWNER FULL SERVICE HISTORY,VERY RARE WITH SUCH LOW KLMS,SO BE VERY QUICK
I have a 4th gen Prelude VTiR with 4WS
Pros:-
i) Looks as if it's going fast whilst it's stopped
ii) Great stance and pose - mean looking to the extent that Alfa Brera lights are so so simliar
iii) H22A1 Engine is solid with reasonable pull at 4800 revs & 142 Kw at 6800rpm
iv) Fuel consumption is about 9l/100Km
v) Good depreciation despite it being discontinued. Originally $53K; can get it now for $9800 in good nick $175,000km
vi) Corners flat and stable. The AUD 5th gen did not have 4WS. The ATTS version is rare (where the outside wheels rotate quicker on corners than the inside wheels.
vii) Great sounding engine
viii) DOHC with VVT, 4 valves/cylinder, multipoint inject'n is bullet-proof
ix) Is chippable despite compression ratio 10:1
x) Susp'n, bushings made to last
Cons:-
i) Rust in sunroof
ii) Rust around window seals
iii) Rust around boot water channels
iv) Heavy front end with FWD can lead to understeer, so one must brake early and accelerate out
v) Synchro wear
vi) Gear box wear
vii) Electronic 4WS can break down (but unlike the Mazda MX6 it doesn't default to full lock - WOW). It would settle into straight pos'n
I could ask no more of a daily than this - to step out of this car and go into a Skyline takes little adjustment
Tez
PS The 5th gen Prelude doesn't look as good as the 4th gen but the ATTS version is worthwhile if you can get one.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
