  • Replies 72
also highly interested in a bolt on solution to twin rb26 turbos, as well as dyno or pics and specs
GTR turbos are easy we can put in ATR28SS 350HP CHAR for twin setup. Those are very very tuff little turbo made to handel high boost. Should get you 400rwkws with excellent turbo response.
very interested, do you have an US dealers ?
Sorry we don't. But we can make them brand new and mail it over if you need. Had many US and Eurp customers lately as our dollar is sitting very low.
Edited by hypergear
I am interested in teting the rb25 bolt on hiflow for you when they are ready.
I can supply you with housings and fit the turbo to my car, tune it and publish the results if you are interested, I have been tuning rb's for a few years and am always interested in bolt on option.
cheers :O
im very interested in this as i am planning on doing it at the same time as a remap,
my car has the usual 'basic' mods (exhaust, intake, fmic, fuel pump, stock boost still)
will somewhere around the 220rwkw+ mark be acheivable with this high flow and a remap in peoples opinions (how much psi would i be looking at runninig out of curiousity to achieve that level)
also what other modifications (if any) would i need to support such power levels.
Edited by AFTDRK
220rwkws is very easy. The high flowed turbo should perform between 230~250rwkws. It should be archived around 18psi or less. By calculation it should archive peek out put of 450HP at 1.3Bar.
There are many dependencies, calculation is normally calculated based on 75~80% of flow capacity. and there are many things that we can do to increase the HP with the ATR28 CHAR in a restrictive environment, but it will results more lag.
The most common profile that we use for R33 high flow is ATR28G2 (400HP) and older G3(450HP) profile. The Current G3 (on the 282rwkws CA) requires a big turbine wheel which the stock housing doesn't seems to have enough meat to be machined out.
Thanks for answering questions etc.
However please be aware you are not a paying trader of this forum, of which there are a lot of businesses paying good money to advertise.
Talking about prices and so on from here must cease until such a time as you are a paying trader.
To become/purchase trader options, please see subscriptions under "my controls"
Thanks.
  • 1 month later...
hey guys, ive sent my turbine housing(not the core) to hypergear today..
ive bein talking to Stao there via email..since i live in perth
anyways..im getting my r33 series turbo high-flowed by them,,
i currently have fmic, pod, hks cat-back exhaust, walbro fuel pump, spitfire coilpack, greddy rs bov, apexi neo afc.
anyways, im just gona bolt this high-flow turbo straight onto my car..
its getting fitted with a ATR28G3 450hp core..
all for $800 :)
anyways my question to u guys is...
will i be able to drive/run my car since i dont have a aftermarket ecu, bigger injectors or a z32 afm..
but ive bein told by hypergear i can..
but 2 workshops here in perth say i wouldnt be able to drive or get my car running...
can some confrim this??
well, they said they can fit a 7psi actuator to it..
so i think im gona get that..
do u guys know what and how much boost i could run with the new turbo?
anyone else running a hypergear turbo on 33 with stock ecu and afm???
I want to see results on a RB20....
If the car's going to be tunned for power I recommend to use 14psi actuator so you can alter boost to 24psi. the 7psi actuator can hold a max of 10psi. So depends on further plans to the car.
Any word on using a ball-bearing core instead of the sleeve bearings you've mentioned earlier - and the extra costing around this? (If you're still allowed to talk about costings in public...)
With BB CHRA it will be a Garrett GT2871R or a GT3071/6R CHRA. To do that it will cost $1200AUD+ depends on the CHRA you want to put in it.
I'm guessing the 2871 would be a more appropriate sizing for 220-250kw and ultimately quicker spooling and response?
It all depends on what you do as calling it "high flow".
What we do is:
Re-profile both factory compressor and turbine housings.
Assemble profiled housings onto ATR28 450HP profile core assemble.
So basically its a brand new turbo with your factory housings for direct bolton purpose.
All ATR turbochargers are covered with 12 month warranty for performance usage.
I have been talking to this guy on NS.com.
So far prooven results with good internals.
gives gt2871r & 3071r garretts a fair run for money! Literally speaking!
For anyone who need rb20 stock turbos for rebuild "cheap as" feel free to contact my at [email protected] or 04218167564.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
