I heard today Gibson used to tune their qualifying GTR's to 12.7:1.... but they also had over 1000 degrees exhaust temps and had to make special brackets to hold the exhaust manifold up as it got so hot it started drooping.
In a track car i'd say that its too lean but thats just my opinion and really its up to you, your use of the car and your tuner. If your tuner says its fine, then its fine. If you dont trust your tuner, find a new one. Second guessing them is no good.
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4308504
12:1 to 12.5:1 on the road is a ok tune but if on track then need to be alot richer as heat takes over and cause issues as Strik3r mentioned
Sorry to hijack, but how much richer?
I had my GTR tuned for the first time last week, and below are the results. The car spends 25/30 days per month in the garage, but will be doing some track days in it.
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4309304
i dunno. in my eyes, for a GTR with decent power, if you're going to be punishing it, it's a bit too lean. and their AFR scaling is so wide as to be completely fking useless. so it's hard to tell even from that graph what exact AFR you are running. BUT on the other hand they have tuned and built more GTRs than i've had hot breakfasts so I would like to think they know what works better than I do. if it bothers you talk to them about it. ask them why they tune it to that AFR, and maybe ask can you have a little more fuel for safety.
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4309319
That is a totally awesome tune. Probly the first dyno sheet i have seen posted on this site that has had a 100% tune. I was impressed, then i saw the tuner stamp so I am not suprised at all.
That tune is 100% safe and perfect for every day street use and track use. how much did that tune cost you? (just wondering)
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4309418
geez, bit hard to say quite how awesome a tune is by looking at AFR. we still need to know timing, boost control etc. but having said all that I reckon my old tune was pretty much spot on. took 3 years of track and street abuse and ran flawlessly and never had any knock to speak of.
it was exactly what I asked for. 11.8:1 dropping to 11.5 right up the top (near limiter for a bit of extra fuel up there, no real loss in doing that as peak power is already past anyway).
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4309433
Thanks mate, it was all the good words about them that i have heard which pushed me to them. And with out doubt the most pleasant dealings I have ever had with a workshop.
All up cost wise was
Nistune ECU - $350
Tune $450
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4309430
Beer Baron, what boost control are you using on that second graph? Holds very well.
Anyone who gives an "expert" opinion on a tune after only seeing an AFR graph, isn't an expert.
For example, my car came over with 11.5:1 AFR's, but pinging its ring off because there was over 30deg ignition timing in the top end.
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4309558
:D
https://www.sau.com.au/forums/topic/248278-gtr-tune/#findComment-4309899
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
