dont see y not, but best call the RTA and get the RIGHT answer.
also, y would u go through the trouble mate? car wil go like a pig. best save ur money, buy a N/A car for now, and worry bout getting a turbo car once ur off ur P's
its not for me, my car is in my avatar. Its for a friend and she has her mind set on a skyline the problem is there isnt many decent non turbo 34's on the market. i thought it may be easier to buy a turboed one, then take it off coz you could replace it once on opens.
Its illegal in Vic
Its illegal in NSW
So for now ill guess QLD would be the same. The reason being the car is build plated as a turbo. Therefore even if the turbo is taken off, it doesnt matter.
You'd need to go through the entire rubbish of engineering, papers to confirm the change and it meets ADR's etc (as emissions would change)
But, that all depends on QLD law, no two states are the same
MAte pretty sure there is a few places in QLD that supply them. Just take a look at Import shops around the place... Mind you be prepared to pay top dollar as Dealers realise kids still want imports but cant have turbos cause of laws so you will be paying extra for it =]
+1 agreed on all the above.. i do believe it's illegal but check qld transport.. and would be slower than an N/A for the few yrs she drives it.. are GT4's p plate legal?
But what do you mean there is no decent non-turbo's around? they will be in pretty good nick.. havent been thrashed etc..
1. Illegal in QLD because as said by R31Nismoid its still a turbo'd car on the build plate. If you got everything engineered and mod plated then it would be legal, however think of the costs to do that.
2. The costs involved in changing over the exhaust manifold, turbo and dump pipe for extractors and an exhaust, then removing the intercooler, pipework, bov, lines etc to the non turbo stuff, let alone the ECU etc would cost a decent amount unless you got all the stuff for cheap however the engine is still a low compression engine so would run like crap.
3. A turbo'd skyline with the turbo removed would be slower then a non turbo skyline due the the low compression so where's the point in that?
Edited by PM-R33
Its illegal in Vic
Its illegal in NSW
vicroads told me it was fine... that was when i had my heart set on an R32
after getting my L's, i dont care what i drive for my P's LOL
You can drive anything on your L's (with a fully licensed driver), just not on your P's....
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
