Hi guys, I got my poncams installed today with 260 on the exhaust and 256 on the inlet with type-a valve springs.
I have a HKS GT2835 Pro S turbo, front mount, exhaust, all the other usual mods, injectors, fuel pump, Power FC etc. Before I got my cams installed I had a healthy 272 rwkw.
Today, with the cams installed I only got 258 rwkw!! Not only that, the boost came on later!
Now, the mechanic (I won't mention who it is) told me that before he was running 18 degrees of ignition timing, now it's running at 14.
Also, from the boost curve, he said that my boost controller, which is a turbo tech one, can't hold the new air flow the cams make, that's why there is a big drop in boost!
Frankly I am !ssed off as I spent $3,000 getting the cams and getting them installed, all to get less power with more lag, wtf!
Mechanic said I must have bad fuel in the car, because if he tried to run it at 18 degrees, he said it was pinging like crazy.
People, I need your help, and opinions as to what the F#%k is going on, and what I can do to fix it!
ALl the mechanic said was to use BP ultimate and get a apexi power fc boost controller next time for the tune and it should be fine, what do you guys think??!!!!!!
I attached the picture of the dyno before and after, please have a look and tell me what'sgoing on!
https://www.sau.com.au/forums/topic/248691-r33-skyline-gtst-turbo-cams-issues/
I was under the impression that Tomei Pon Cams for hydraulic RB25's (R33) were 256 deg duration inlet and exhaust .
I had though the R34 versions were 252 and a tad more lift than the R33 hydraulic ones .
You may want to double check the boxes because there was recently a mix up between inlet and exhaust cams and almost R33 and R34 types .
No names but check all the part numbers .
A .
Sounds like a very similar problem i had man, but with my old HKS cams.
http://www.skylinesaustralia.com/forums/Di...+Valve++springs
No matter what we did we couldn't figure out what was going on. Ended up selling the cams, ripping the head off to check everything and now rebuilding the entire head with new cams.
What cam are you using on the exhaust side to get 260 degrees?
A .
THe inlet was a poncam 256, and exhaust was PROcam 260.
What you're saying that he could've put the 260 on the inlet side and 256 on the outet?
Nah that aint possible to do, the cam gears won't go on the wrong cams. But yeah running the procam on the exhaust side is a bit questionable. I thought the procams were only for solid lifters?
Check to see if they are on zero, all the cams I know of are already dialed in for a zero setting. Set them to zero and have a drive - you'll need a retune as well. I did the same thing with mine, and the tuner was more used to GTR tuning so wasn't aware that you set to zero for Gtst's. I went from 245rwkw without cams to 215rwkw with cams....bummer.
I reset them myself and the power difference was huge and very very pleasing. Got a tune later and 257rwkw.
You don't just set the cams to Zero degrees.
They NEED to be dialled in properly.
Also, running different sizes from inlet to exhaust does different things with the engine.
You will most definitely HAVE to dial them in to make the most of it, and this is why your power will be out and your ignition timing.
poncams on an rb will bring up your top end BUT will delay your boost threshold a few hundred rpm.
eg. my mate and i have the exact same setup, same tuner, same dyno... mine without cams, his with
i make 265rwkw with full boost by just under 3.5k
he makes 275 rwkw with full boost by just under 4k
Could bad fuel really cause the tuner to have to turn down the ignition timing from 18 to 14? (98 ron stuff).
Could the cams them selves be making the car ping?
I run BP Ultimate and my top end map is running between 12-14 ignition timing any more and it would detonate. I think you will find most PFC maps with skylines running decent boost will be very similar,I'm running 18psi with a 3037.
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
