If your having too much knock problems even with a good tune install a water methanol injection kit cheap insurance and higher timing + you won't blow the internals too quickly, my na+t two years still going hard! Rebuild it later
  • Like 1
Will post a link, or type boost cooler into search and one guy has a full write up on it, the kit is 648 and should only take 2hours to install and basically sprays a mist as boost rises to prevent detonation as the load increases so does the mist, you get a 2l tank which you mix 50% methanol and water the guy who did the write up says 2l lasts a full tank, so I'm going this path soon will post my own results later
Bhp any different to hp? Because 310 hp is why wytsky got of bhp is different than that would be higher number
I'll post my results when I get home it's too hard from the iPhone
Ok now that ive done my research the brits measure power output at the engine not at the wheels so your 315bhp is around 235kw at the engine there's no way you'll make more than 220rwkw on an old stock r33 turbo in other words your rwkw figure is around 185rwkw
And now that I've seen the graph it's actually 185rwkw so 250hp at the weels so your down 60hp on him + he's got 4wd so that's at all 4 wheels
brits measure in both fly and wheel/hub and mine is 315bhp at the hubs which is 378 at the fly on a standard r33 gtst turbo at 10.13 psi boost,i don't know where you did your research but its wrong,my 1st dyno was 301bhp at the hubs at 8psi boost and i still have meth/water to put on but i have not had the time yet
Edited by lammy426
Whatever everyone knows the r33 stock turbo will shit itself at 220rwkw and sometimes quicker, just saying your graph is saying it's flywheel hp anyway enough said not gonna argue about it but just going off your graph, later!
Ps I don't know anyone making 224rwkw with 8psi on the stock turbo... Do you? That's why your wrong!
Edited by DaGr81
they use their old paperwork on a new dyno,and the inlet plenum makes 40/50 bhp more than stock and electric fan gives 3/5bhp,cold air forced fed, and 224kw is probably on a low comp engine an ordinary gtst,i've been a mechanic for over 30 years,but obviously you know more,by the way there is a post on skylineowners.com which states thor racing say its fly bhp but its really hub bhp. i want to see what n-dawg comes up with if he gets 10 psi he should get around 300/310 at the fly bhp that is as a mate of mine as, and a member on here called shawny <a href='http://www.skylineowners.com/forum/showpos...mp;postcount=23' rel='nofollow' target="_blank" onclick="java script:urchinTracker('/outgoing/www_skylineowners_com');">http://www.skylineowners.com/forum/showpos...mp;postcount=23</a> http://www.skylineowners.com/forum/showpos...mp;postcount=21 http://www.skylineowners.com/forum/showpos...mp;postcount=24
Edited by lammy426
By saying you make 378 hp at the engine is even worse your saying that you make only 22hp less than what a 400r gtr makes when it rolled out of the factory... Either way I have not seen plenums make 37rwkw (50hp) on a engine which only has minor bolt ons and a tune.... Everyone comes up with the excuse "I've been a mechanic for bla bla years..." give it a rest if your a mechanic why didn't you do your own install...
Enough said cya later key board warrior
i did do everything myself except the mapping and the alli welding,if i had the facilaties i'd do it all,i've watched sau for a few years and you are a muppet you have not read the posts properly,all i want to do at the end off the day is help skyline owners to get the most out of thier cars,if you continue to disbelieve me and nobody cares what i have learned over years of trial and error. and the cars been running 300+ath for 2 years + at the moment
well, its actually a gts4 box, apparently they are as good as the gtr's, so I have heard....
and I got the car dynoed, need to upload the sheets, got 220-230rwkw. but had boost spiking with my bleed valve :angry: so getting a gizzmo. we also think my exhaust is being a little restirctive because it has a large dent in it.
wytsky, are you using the standard rb25de gearbox or did you change to a 25det?
i'm still using a standard rb25de box with an r32 gtr exedy clutch,for about 2 years and its been ok so far
Here is the current dyno.... as you can see, there is pretty bad boost leak between about 4500-6000 ...1.3 bar is about 17psi i think?? fair bit for an n/a.... im not happy with, especially considering it was making more power then this on a solid 14psi with no creep...
the green is before, and the red is after, so there was a little more poke down low before, but uptop theres a little more now.
ordering the gizzmo next week, then back on the dyno, testing exhaust, and bits and pieces. so hopefully we can get the last 1500 rpm to point up high and get a good figure... instead of looking like an old man's set of knackers :D
Adam
  • 3 weeks later...
hehe, nar different dyno, different formula and measurement of working out torque... he believed it was quite alot for the power the car is making.... I'd love to know the conversion formulas between dynos if they exist or any1 knows.... so I can compare between.
Model - R34 25GT Sedan
Engine - RB25DE NEO
Modifications / Parts Used - RB25DET Factory Exhaust Manifold, R33 Series 2 Turbo, JJR Front/Dump Pipe, Custom 3" Mandrel Bend Catback system with 5" canon tip, Magnaflow Hi-Flow Cat, R34 GTT Injectors, Walbro GSS342 Fuel Pump, Monsta Performance FMIC Kit, Turbo XS Recirculating BOV, Apexi Power Intake Air Filter, custom speed flow oil and water hoses with speed flow fittings, extra silicon bends (90deg short silicone bend and 90deg long silicone bend), new set NGK Iridium spark plugs, heat shielding, factory piping (turbo inlet, hot pipe from the turbo), oil pressure switch adaptor, T3 foot gasket.
Engine Management Used - GReddy eManage Blue with optional Injector and Ignition Harnesses and Ignition Signal Adapter for R34.
Fuel Used - BP Ultimate 98
Boost Used - 7 PSI (straight off the RB25 Actuator)
Dyno Tune Results - 211.9HP
Misc - New coilpacks will probably net a bit more gain, fried one same day after having conversion done. Splitfires on the way. Also been told that the dyno used tends to read a lot lower (10-25kw in some cases) but I'm not going for big power figures just yet. Auto transmission + N/A+t = not so great, will definitely do the valve body upgrade. Also on an R34 i advise changing the intake plenum/manifold.
All up it actually took more than 29.5 Hours charged, the workshop put extra labour in here and there on their own time (this also included after sales service such as temporary coilpack replacement and additional tuning after fitting the BOV). If another workshop done the same job it could easily be a lot more.
Spend extra on a decent FMIC kit. I got mine very cheap (lucky ebay bid) but the piping was pathetic and added to the install time, not to mention otherwise unnecessary cutting of the black plastic grill in the front bar simply so the modified piping could line up.
Splitfire Coilpacks will easily add $640 to the cost as well, but I see things like the coilpacks and spark plugs to be a maintenance thing anyway. We all know that R34 coilpacks don't last forever. Note that coilpacks aren't fitted yet...probably won't know what extra power it may add either, but people seem to report that they pull a few extra KW's with them.
Costs - Parts: $2,800-3,000 Approximate Labour & Tuning (29.5hrs labour incl. 4-6 Hours Dyno Tuning and install of the eManage): $2600.00
Dyno Graph
    • Hot tip, stop picking at shit. Live in bliss instead   From my recent experience in rust repairs, white it may seem to not go much further back, you'll still need to cut back a bit further.  From what I can see there, the outer skin, and the inner is rusted too. From what I can see you've got the inner one which is all structural, and window likely affixes too.   If tag Murray Calavera here, but my phone won't let me tag him, he'd probably be able to give the best advise.   I do know, welding roof panels is a right pain in the bollocks! Very heavy to heat distort the roof and warp it all.
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
