  • Replies 49
I'm suspicious of mine, was 3years old when I got it, only 45,000klm. Now got 86000klm, I've already changed timing belt.
Only mechanical problem has been needing a new crank angle sensor.
And heaps of brakes and tyres :)
i bought mine three years ago with 40,000 on the clock, ive got 125,000, the only things ive changed were clutches brakes 2 times, timing belt and water pump, i can hear noises coming from the diff and driveline, oh well, launching the car all those times over the years its no suprise, my car was 6years old when i bought it
I wouldn't worry about that - that's pretty much normal for a a city bound 3 year old car here. I'd say that average KM's for a 3 year old car are around 30 - 50K KM. But, if you're unsure, go by the condition of the seats, pedals, etc...
Got mine last Saturday, 71,000km on the clock, and looks genuine as the interior is immaculate as is engine bay etc.
Only problem is the second turbo decided to call it quits after driving back to Canberra from Sydney, doh :P
But Ive only had it 4 days but love it to death already :P
Got my R33 just over a year ago with 32,000 documented kilometers, just turned 38,000. I hate to see the kilometers rack up so I'm looking at getting a nice cheap low kilometer S13 Q's to drive to work in.
My last car(A31 Cefiro) I bought with 82,000 and got rid of it with 112,000 Kms. Nothing but problems with it, tranny on it was about to die(slipping) when I traded it up for the Skyline. It's great not being nickle and dimed like I was with the Cefiro now, had zero problems with the 25t :P
Reading all these posts got me thinking. Out of curiousity - what do Australians consider to be "high mileage" or "High KM's"?
It's my experience living here, in Japan, that anything over 100,000 KM is regarded as very high. In fact, with the exception of classics and sought after cars, it's hard to find any car for sale above 100,000KM - well, not ones fetching reasonable prices anyway...
A good example was my old R33 GTS. Excellent condition. 2 Owners. 90,000KM. Got a lousy 30,000 yen when I traded it in to buy an R34. (and I had to twist the dealers arm to give me that much for it!!!
BTW - I'm British and as I recall, in the UK 100,000 miles is considered "High". :P
We think the same thing in the states. I always found it amazing that the Japanese consider 100,000 KM to be high, that's only 62,000 miles! I guess there is a stigma surrounding the whole 100,000 mark.
my GTS25 has 96000 now. almost...95xxx..not sure exactly
bought at 86 in may this yr.
my daily driver albeit the occasional "whack" in the bum altho dont expect much cause its a non turbo...tho that will change in abit.
:P
going strong...had a slipping clutch...due to launches..changed it and it goes fine now. whining gearbox...god only knows why..
rusty screws here n there but totally immaculate interior...seats and pedals...only started to wear when i got the car...
gee...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
