Coolermaster HAF 932 case
Corsair 850w modular psu
Noctua d14 CPU cooler
8 gb gskill ripjaws 1600 8-8-8-24
Intel i7 2600k (oc to 4.5 ghz with no vcore change. Just multi - not finished ;) )
Gigabyte gtx285
Giganbyte ud5 mb
120gb ocz SSd 285mbps read/write
2tb caviar black (games)
2tb samsung green (media)
1tb caviar green for random (pr0n etc. )Rofl :P
SuperPi 1m = 7.6 secs.
26 degrees idle.
48 degrees max on burn-in test after 4 hours.
50 degree max on prime-95
Edited by ShiftyTys
nice overclock, pity you wasted it by putting your games on 5400rpm drives @_@
Do you know what a WD caviar black Hdd is? It's just the fastest spinning drive on the market. Forget raptor. Inneficient way to increase speed by rpm. Also you see the SSd there? Important games on there.
How is your Prime95 hotter than IBT? :ermm:
ITB will usually see 10 degrees more than Prime in every PC I've ever built from standard E5200 to overclocked everything!
Someone gimme 1800... I need to regeek myself. All i've done is build home/stocker PC's for friends the past 6 months.
Nothing fast or remotely interesting :(
Different days. In fact I was gonna say idle temps for the day, before the load temps in my post. But then I CBf. Lol
Yeh 1800 for my rig. Oc the 2600k is bliss.
My Setup
LAPTOP $699
BRAND: ASUS K52F
OS: Windows 7 Premium
CPU: Intel Core i3 370M, 2.4GHz
VGA: Intel Graphics Media Accelarator HD
DISPLAY: 15.6 HD/LED BL
HDD: 320GB
MEMORY: 3GB
GAMING COMPUTER $450 (Swap Meet Build)
BRAND: None
OS: Windows Vista Ultimate
CPU: AMD Athlon II x2 255 Processors (2 CPUs) 3.1GHz
VGA: NVIDIA GeForce GT 430
DISPLAY: Pioneer 50inch TV
HDD: 500GB
MEMORY: 2GB
For what part? :D
Plenty of parts that can be checked lol
Although i dont check my CPU anymore. It's run 4.2ghz or whatever daily for almost 3 years now, never got hot in the first 6 months and that was good enough for me.
Although i do make sure i clean it every 3-5 months from dust etc. And i do check the CPU after reseating the heatsink
  • 4 weeks later...
Would it be worth buying say a 60gb Solid State Hard Drive just to install Windows 7 on? And then run my games etc off another 7200rpm hard drive?
By doing this, will it effect games performance in a positive manner?
you'll see better boot times, but games won't really run any quicker.
I looked into it for mine, and thought "nah f**k that" and didn't have the cash for 2x VelociRaptors, so Caviar Blacks it was!
2x Velociraptors in RAID 0 will kick an average SSD and have al ot more space!
The PCI SSD's are still not as cheap as the 2nd gen SSD. They are line ball still even though they should be cheaper theoretically.
3rd Gen SSD's are coming out. I've been watching as I'm due to a refresh in the next 6 months and intel is due for another update in Q4 i believe.
So end of year will be good timing i think.
SSD wise - put the game(s) on it also. just having it on the OS is only boot time and sometimes load performance. However games do benefit from being on a SSD. No doubt about that
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
