So how did you plumb it in? Back to the original tube or some other way? I'm guessing it was easy enough to do in the car
I connected it to the original metal pipe on the gearbox, had to bend it out a bit more to get access from underneath.
I reckon if the pipe was facing where it's meant to (forward) there's no chance to get to without dropping the rear of the box, so kind of lucky that mine's bent...
I put the filter close to where the tube comes out he gearbox, aprox 200mm away. That way you dont see it.
Yeah I put it up visible so that I can keep an eye on it. Can't be good if there's lots of gearbox oil climbing that far up. Fingers crossed.
Does it just vent down from the filter then?
Yes, you can just see the end of the top pipe coming back down in the 3rd last photo above, see the top arrow.
I believe the factory breather pipe vents to atmosphere the same way, just without the filter in between.
The first time I had this stuff in my gearbox it was fine. Now with the second lot it does it. Someone suggested a batch issue, which may be the case. I still think I'll try the super lightweight next time though
  • 1 month later...
A quick update: I had a look at this after some sustained spirited driving recently and indeed, Redline does climb up the breather hose all the way to the filter cup that I put in. It didn't quite touch the filter core though. So overall this setup works well, and I'm not surprised that some of you have seen smurf's blood under the car given that the factory breather end sits lower than this DIY job (and doesn't the filter of course).
  • 9 months later...
i saw your original thread where some people mentioned a bad batch of shockproof? My gear box was freshly rebuilt couple years back and was just sitting until recently.. prior to that it had bad syncros which shockproof heavy took good care of.
Once it was put back together i put heavy back in there but on cold starts it was hard to shift, so went with light version.. since then we had only put some 200 miles on the car since its not a daily and noticed spitting of fluid out of breather.. without hard driving conditions.. I have not tried changing the fulid to non-shock proof but seems like i should try this plastic fuel filter thing for solution?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
