  • Replies 2.5k
Posted Images
Massa will be fueled right up this time perhaps with a few kg's extra (just in case) and he is a good chance of cooking his rear tyres so the closing laps for him should be fun.
Turns out he had enough fuel to finish without conserving last race....It was the data that was wrong, but obviously they didn't know the car had enough fuel until after the race when they checked it
really, is that right? ouch for ferrari
i thought his car stopped on the cool down lap. i was overseas and it took me a while to find a tv to watch the race and my italian is a bit sketchy.
I'm only going by what Massa told reporters in the pre qualifying interviews
Save for any mad acco that sees him out for some races, I can't see Button losing the WDC this year, and after only 6 rounds :)
Can't see the team losing the constructors title either, really.
The Brawn GP procession is getting a bit tedious though...
Why RBR didn't pit Vettel earlier when the SS tyres had expired has got me f'ed....
He certainly burnt his rear soft tyres up quicker than anyone else during the race! But he didn't really have any pace even in the first few laps before they would have gone off. I don't think he got his setup anywhere near right.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
