  • Replies 2.5k
Posted Images
Pos Driver Weight (kg)
1. Alonso Renault 637.5. Should Pitt roughly lap 13/14
2. Vettel Red Bull-Renault 655.0. Lap 20
3. Webber Red Bull-Renault 652.0. Lap 18/19
4. Hamilton McLaren-Mercedes 650.5. Lap 18
5. Rosberg Williams-Toyota 654.0. Lap 19/20
6. Kovalainen McLaren-Mercedes 655.5. Lap 20
7. Raikkonen Ferrari 651.5. Lap 18/19
8. Button Brawn-Mercedes 664.5. Lap 23/24
9. Nakajima Williams-Toyota 658.0. Lap 21
10. Massa Ferrari
11. Buemi Toro Rosso-Ferrari 671.5
12. Trulli Toyota 671.3
13. Barrichello Brawn-Mercedes 689.0
14. Glock Toyota 679.2
15. Piquet Renault 667.7
16. Heidfeld BMW-Sauber 658.0
17. Fisichella Force India-Mercedes 680.5
18. Sutil Force India-Mercedes 683.5
19. Kubica BMW-Sauber 666.0
20. Alguersuari Toro Rosso-Ferrari 675.5
stolen from autosport.com
Alonso has gone light and aggressive, button running heavy looks like tomorrow might be very interesting although I'm hoping for another red bull 1-2 I feel buttons got a chance of getting decent points this time.
I also did a rough estimate of when they should Pitt for fuel, but ofcourse you can never be too sure they may switch strategies or it might rain.
Edited by DaGr81
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
