Hi guys,
Just wanting to know if i should be upgrading my injectors for my power goal of 300rwk. Too many different opinions which has got me puzzled.
If i do require injectors what ones will slot into the stock fuel rail?
mod list as follows
-nismo fuel pump (intank)
-stock dumps,
-jjr front pipes, hiflow cat and 3 1/4 catback exhaust.
-wolf 3d ecu v400
-garrett 2860 -7 turbos
-100mm thick fmic which came with the car
Ive tried searching but couldnt find my exact answer.
Thankyou
All I know is from everything I've read on this forum.
I'd say yes, you will need new injectors. 550's should do or 600's would be plenty. Perhaps Nismo, or Sard's would be cheaper.
Have a look in the sticky threads on turbo upgrades. See what people are using appropriate to their power output.
Although U have seen a mates car pump out overr 300 RWKW on stock injectors and fuel pump, I wouldnt encourage it.
700's would be more then enough. Dont go 800 CC Sards, our have to change the plugs for them!
As said in previous post 600 or even 550's would be enough.... Im a man of overkill so hey! :)
Nismo 550/555's, i forget the size but its one of the two
All you need, thats all i have in my draw for when i need em :)
Stock injectors can do it with a FPR but you really do want injectors ideally.
so on stock injectors, what sought of power levels (rwkw) would you not go past.
for in stance, would you be maxing out at 270,280rwkw??
i wouldnt bother pushing them at all just upgrade, i made the mistake pushing mine which ended in disaster 280rwkw bumped up fuel preasure running at around 96% duty on safe tune all sweet untill no.6 injector burst which leaned out the cyl and melted the piston. 700cc +1
i am getting too many mixed opinions on injectors. And im just confused now.
apparently the stock plug needs to be changed if i go the sard 700's?
All i want to know is what injector is an oem replacment between 550cc -700cc.
part numbers etc would be a big help
ty
Edited by R33GOD
can anyone confirm but i read sometime ago, to use the highest flowing injector on the leanest running cylinder?? is that cyl 1 or 6??
anyone know sard 700 latency??
Cyl 6 is the LEASEST cyl.
if you look at the plenum on the rb26 no.6 port it comes in to cater for the clutch booster i think, and causes no.6 to get starved of air or something in hight hp engines, nismo do a replacment bolt on plenum and gready do one to that fix this
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
