They can be defectable yes.
As long as you get a sensible colour temp and have your headlights angled properly i dont think you will have a problem.
I have HIDs in both of my cars and never had a problem.
I heard you weren't allowed a different colour light at all? What do you mean by angled properly? I really want blue lights but not if i'm going to get defected for it lol.
  • Replies 74
Hi mate,
The bluest i would go is 6000k,the jump to 8000k is very blue and will get some unwanted attention.
You should always check your beam level after installing HIDs. What was once an ok height with halogens might now be blinding other drivers.
90% of the time you will need to adjust your headlights down.
Here are actual colour temps of the BOSCH HID kits in action.
4300k
6000k
8000k
I would only recommend the 8000k if you had projector style headlights such as these. 8000k in the reflector style is just too dazzling to oncoming drivers and does attract unwanted attention.
Hi mate,
Okay, i'd be going for the helligkeit HID kit if i were to get some lights and isn't 6000k in the helligkeits a diamond white, not a blue?
Also how long does it take to recieve these lights?
Steve both your kits sent over this morning.
and3_3 kit was also sent this morning.
GTR-8OY your kit has been ordered, should be sent out mid next week,
:cool:
Ok im a newb when it comes to lights, what's required for the helligkeit HID kit to fit a 1989 R32 GTS4? I'd want the 8000k in blue-ish like on the tiburon with the c/f bonnet. Can you PM a reply with price and the exact ones I'd need? Thanks alot! Cheers James.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
