I love wank, but I also love not damaging my rims when simply removing them from the car for something. These from MOB are pretty cheap but they are allen key lugs. My WORK lugs (21mm socket sized) weren't cheap and they are soft alloy and sprayed blue on the inside :cheers:
Here's my Bronze 5Zigen's with WORK lugs, I have already cross threaded 2 of them trying to REMOVE them.
Edited by Topaz
Standard 19mm HEX the Rays are. I paid $200 from memory.
They'd be perfect nuts, my current nuts are slightly larger nuts so smaller nuts wouldn't rub the edges of my rim :blush:
GIT SUM NUTS@!
Edited by Topaz
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
