Guys I have a Series II rb25det in a S14 240sx. I cannot get this thing to run correctly. Everything is completely stock except a front mount intercooler, 2.5inch downpipe and 3inch exhaust and a walbro 255hp fuel pump. After driving the only code I get is 21 ignition circuit. Feels like antilag. I have already tried a different afm and a different cas and no change whatsoever. Any help would be appreciated. I do know about the rich and retard and I have no knock sensor code. I have bought the resistors to bypass rich and retard but I have not tried it yet. Thanks in advance for any help.
https://www.sau.com.au/forums/topic/250672-5000rpm-timing-retard/
Going back years, but i had a prob like you describe when i first got my series one. Although your car is mainly stock, boost will rise above stock due to the cooler and exhaust, and when the ecu see's up to a certain level it will pull timing, which on mine occured as you describe. When it was cold weather i would get what sounded like rev-limiter like pop sounds as it went through that flat range. Anyone correct if thats wrong.
I threw on an FC and got a tune which sorted everything out.
how much boost?
had the same thing with my s1 25, running about 10-12psi the power curve would take a dive then when u hit 6200 it was like hitting vtec. just the stock ecu going rich n retard. put it on the dyno at the time to make sure it was running safe -
http://i224.photobucket.com/albums/dd251/J...17052008009.jpg
error 21 can include coilpacks, a very common problem.
my car did the same thing, seems to be a common thing with the RB25's. Trent at Status was able to take it out with a remap, so it was prob the ecu pulling timing.
considering it's an ignition error, what you checked the coils/spark plugs? how new are the plugs and what are they?
if you're in melb, take it to Trent @ status
Thanks for the replies. Boost is around 9.5 - 10 psi. I am using NGK BCPR7ES plugs that didnt change the problem so the plugs are a week old and are gapped at .8mm or .032. The thing is the car will do this with part throttle and sitting still. If I go full throttle sitting still you cant feel it, except for when you are driving. Last night it fouled my new NGK plugs out just by free revving it. Im stumped. Jonno that dyno looks like the way my car would feel. Its like trying to push the great wall of china out of my way and then it clears up and Im on the rev limiter before I can catch it.
Edited by boostedfe3
mmm sorta sounds like the same prob im having but mine will do it from down low till high rpm and only before the car warms up
im smelling raw fuel at some points so im getting some sort of ignition cut or fuel up, im sorta hovering around crank angle sensor
I thought cam angle sensor also. I tried a different one that came off a buddies car and same thing. Stupid stock ecu. Since I have a series II and live in the states, can I just find a series I ecu and have it remapped. Really not looking to go to a standalone ecu at the moment.
code 21 is no ignition ref, 25det's run internal ignited COP, the coils send back a ref signal to the ecu to say they have fired correctly. code 21 is logged when the a ref signal is not receive for more than a couple of revolutions. the fact that the mis is evident at 5000rpm(probably full boost, high engine load) would indicate that the coils are starting to fail(it's harder to spark at higher cylinder pressures). the engine will probable light load free rev through 5000rpm without missing
failsafe/limp for error 21 may include timing map locking and possible fuel map supplement.
try swapping the coils if you can get hold of another set, or try diagnosing which coil is failing and swap with another cylinder to see if the misfire moves to that cylinder.
also check your camshaft as the splines for the cas wear out and cause all sorts of timing problems as there is too much play between the cam and cas splines. your prob sounds like rich and retard with a bit of coil pack break down thrown in lol
you guys think I should try and disable rich and retard and see what happens? and once again thanks for the responses. Also keep in mind I have that the car does this sitting still and free revving with part throttle.
oh ok. I was under the impression that it would disable it, but I understand what you are saying also.
If you don't want to get a computer consider getting an Apexi SAFC (an old cheap version will do) and an Apexi SITC both usually available on US ebay. Otherwise you can't really tune your car at all.
ok will look into the afc. No I have not checked the fuel pressure yet, although that is next. I almost think that it is running way rich. when the car is warming up I get lots of brown smoke out the exhaust. And Im not getting any codes at all now and I have been driving it for a couple of days.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
