wat dan means by hitting it is the cover on the back of the headlight there is a cover togain access to the bulb and it has a tag that sticks out and nissan puts a torx bit screw in the way to stop the cover from beign undone. just undo the screw and then you can undo the cover. i think from memory the screw is a tamper proof torx bit.
I installed those 6000k's that Dan was selling and they look superb. They don't look blue at all and haven't attracted any unwanted attention at all.
I do find however that I had to lower the level of the headlights to the lowest settings (my 34 has that level adjuster knob under the steering wheel) On middle setting I was getting flashed by oncoming traffic so hmm .. but that was same day as I cleaned my headlights so might have had something to do with that and not the new globes. Either way even on lowest level setting they look great and put out good light.
  • 1 month later...
Hi All,
I have recently got a new set of 6000K bulbs from Dan and they look the goods! Quality light output.
Delta Force you mentioned above that you had to lower your headlight adjustment. I need to do the same in my R34, however on the lowest setting on the in car adjustment my lights are still very high and I get flashes from oncoming traffic.
I have adjusted the screws on the top of the headlight unit itself, this has made little difference. Also the right headlight is sitting higher than the left. Is there any other way besides the above that I can move my headlights to face down a little more? Has anyone else had the same problem? Is it a common problem with R34's? Not real keen on taking the front of the headlight off with a heatgun....
Any advice or help would be greatly appreciated.
Cheers - Kyle
Hi All,
Cheers - Kyle
Kyle, yep I've got no idea about why your height adjust isn't moving much, on my car at 1.5m distance to a wall I get a full 75mm drop from the high to the low setting, so on the road you ca imagine this is a marked change in distance.
Is the adjustment motor making a good bit of noise when it works, or does it sound like it may be sticking?
  • 11 months later...
Sorry to dredge up an old thread, but I would like to know if there is a significant difference between the brightness of light produced between the 6000K and 8000K bulbs. My stock bulbs are terrible and I think it is time to replace them before they become too dull and a safety hazard.
Would also be curious to know if anyone has installed a 6000K in one headlight and a 8000K in the other to show the difference in colour and brightness?
  • 1 year later...
hey :) i have 10000K 35watts :) ebay kit (see below of coloure) there really blue but no good out of town ... i went and brought a 2nd kit 100W 6000k white kit and installed it in my 34 wires still going strong running 4ballest ... 2 kits :) i can add pics if you like
  • 2 months later...
I've had a HID kit sitting here for nearly 2 years, i was quoted $400 to install them and thought f**k that and never got around to doing anything about it, but after reading this thread i'm keen to get them in, i'm on the central coast of nsw, and i'm looking for some one to come do it for me, ill buy you a case or drop some cash your way *not too much im quite poor :P*. any takers?
Is it correct that the Higher you go in Kelvin the less light lumens you get? So the less actual light?
As for standard, I live in the country, no street lights at all out my way and when driving my Stagea at night I never use high beam, so standard "should" be fine for most people.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
