  • Replies 124
The BOV was tightened right up and works fine. It hasn't got a gates timing belt. The rubbing noise went away as soon as you loosened the front bolts. It ide's fine and revs at idle with no problem (except for it backfiring when you take your foot off and the revs fall back to idle. No blue smoke at all. What 3 cam timing marks are you talking about? One option i thought is to pull the cam out and get a CAS that has the key in it. and get a cam that has the opposite key. Just so i know thats fine. But im guessing thats alot of work if it's not going to fix the problem.
they key in the cam just makes it easyer to line up the timing no need to change but when putting the CAS you have to take extra care in making sure its in the right position
But if the timing was ligned up at the 0 mark on the crank with a timing light wouldn't that say that the CAS is working fine and the cam is in the right spot? And how do you know exactly what point to put the CAS in?
The workshop is very unlikely to lend you their tools and hoist to do the work for yourself, what do they get out of it? Plus their are insurance issues they would need to think about by letting someone in to work under a hoist that doesn't work there. Bit different if the engine was out and on a stand, but not on whole car up on a a hoist
Seriously dude, rather than just get everyone to list every possible thing it could be, just pick the car up, thank the workshop for their time and "effort" and take your car somewhere else. You will probably find out that it is something very simple and take not much time to fix, or it will be something major and take a bit of work, either way at least you will know what is wrong with it. If the new workshop can't find the problem then you haven't lost anything except maybe a hundred bucks for trailer hire and a bit of your time.
That and your car will look like a fully sik tokyo drifter on a trailer lol
I have already worked on the car while it has been sitting on the dyno. and i have taken my car to another workshop before and they were hopeless. This workshop seams to be good just a really weird and hard to find cause.
Im starting to wonder.... What would have caused the PCV valve to blow out during a dyno run? Because all these problems started to happen after the car popped we found the gromet had split and the PCV valve was sitting out a bit.
Except for you saying it holds boost, I'd say a stuck open wastegate. Is your actuator arm actually working, and it def. holds boost? Then again, a std motor should make more than 48 kw even without FI.
try a different ignighter module then if its a series one.. knew a bloke who had a similar problem, everything seemed good and they couldnt figure out why it was only making 96rwkw on 1 bar and it ended up bein the ignighter module was rooted. just something to think about.
If the dyno is in use, then the proplem should be sourced, we use our dyno as a diagnostic tool, not a tuning tool. unless the dyno is a VAIN then there should be enough equipment to diag the proplem there and then.
Other than that it mean's the equipment isnt being used correctly.
Edited by EFI Performance
Not if that's the timing at idle. It's supposed to be 15BTDC. If it's only 0 (TDC), then the spark is firing 15 degrees too late right across the range. Considering that at full noise, the timing might be supposed to be 10BTDC, then it's actually firing 5ATDC. That's into the power stroke - no wonder it can't make power!
The key on the exhaust cam controls where (at what angular relationship) the CAS mounts. Without the key, the CAS can only be in one position for the engine to run - any other position, and it just won't start.
So if the cam marks are where they should be, The belt hasn't jumped a tooth and if the timing light is showing the right angle then this would rule out the cam? Or would i still need to replace the cam for one with a key and the CAS for one with a key?
Car sitting on a dyno is not the same as car being on a hoist. End of the day it is up to them if they want the potential legal problems it could pose if something went wrong. I'm with Drag and GTST, try the ignitor and the CAT, forget about the cam for now, do the easy quick stuff first!
The loom for the coils plugs into the ignitor. Should be a silver metal thing with finns on it and 4 screw holes. On a 32gtr it sits on top of the valley cover at the back of the engine, dunno bout 33 though, and 34 have the ignitor built into the coils
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
