I am very confident I could pop each and every one of those 3 you have had on an Rb25 within a day , given a go at them :blush:
how exactly? without increasing the boost it'd be the same as every other day for the last year
not really worth it but myne made a touch more peak power on 15psi than it did on 13
bolt on ebc so it actually holds 1bar till redline (big difference between getting to 1bar and then dropping boost as revs climb) and then take it to the local circuit on a sunny day. guarentee I'll get you 3 dead turbos before the end of the day.
It's the same bleating you get from some GTR owners who don't know better and it's also actually really a stupid way of increasing performance given the risk.
When the ceramic turbine lets go you can end up 'dusting/sanding' your piston bores with ceramic particles. There are again plenty of examples of 'damn I lost my turbo......wonder why my car is using more oil and compression is down?'. I had some very old GTR turbo's let go.No suprises, it did just that.
I'm not being a kill joy. You can still run a high 12 or low 13 1/4 with just 10-12psi in an R33 or R32 with one of these turbos.
I have.
Want more power?
Go and buy a buy a bigger turbo with a metal turbine easy fix.
I have only heard of this with GTRs, possibly because the twin design is more susceptible to allowing particles back up the exhaust headers. Does it happen with GTS-t's too?
The gtr's are more likely to get hurt but, the same risk is there.
So, judging by this thread, it is 100% true that the Series 2 R33 turbos do NOT Have a ceramic turbine, but rather have aluminium?
And therefore can be boosted higher than a Series 1 turbo?
I'm posing this more as a question, rather than a statement as I do not know the correct answer.
If someone can confidently confirm this, please go ahead.
Regards,
100% wrong. See my first post in this thread (#5).
no they both have a ceramic exhaust wheel. (the back one)
s1 has steel compressor wheel (the front one)
s2 has a "nylon" compressor wheel (the front one) which someone (trent i think...cbf looking) mentioned was actually aliminimum with a nylon component somewhere along the lines
12psi
stand alone ecu with aggressive tune
good tyres
pineapple, camber, castor kit
short shift kit
intercooler
good 3" turbo back exhaust
cold air intake
there wont be much on the street that can beat you in this setup
should make around 190-200rwkw
Hmm not sure about your area you live in Paul, but around here 200rwkw in a skyline just doesn't cut it (for a street car).
i ask how you'd do it without increasing the boost and you say ur gna bolt on an ebc so the boost doesnt drop off, hence increasing the boost :)
probably never get driven with stock turbo again anyway, will have a gt30 within the next few days
i ask how you'd do it without increasing the boost and you say ur gna bolt on an ebc so the boost doesnt drop off, hence increasing the boost :(
If you say 1 bar we mean 1 bar do we not?
If you go around telling people that stock turbos can hold 1 bar all day, then neglect to tell them you didn't mean " 1 bar all the way to redline". They may own a skyline with an ebc and then on your good advice will lead to a nice dead turbo and possible engine damage.
Adding an ebc to 'hold 1 bar' is not "increasing boost" as far as this argument is concerned. It's 'holding boost'.
The GT30 will be fun. :D
I wouldn't bother running more than stock boost unless you get a powerfc or tune your factory ecu as you'll run into R&R issues pretty quick and the car will run like crap.
Since you're in NSW, come down to Sydney .. Toshi can remap your stock ecu for < $500 ie. fix up the AFRs and ignition timing. Much cheaper than a powerfc tune and will allow you to run as much boost as you feel is safe, i'd recommend no more than 11.5psi - that's what mine's set to but I have an R34 GTT.
  • 1 month later...
my car only has pod filter and a boost controller set to 10psi running over a year now. Making 150rwkw at least. Just had 9/12 manifold bolts replaced and turbo gasket replaced due to all of it being broken or cracked etc. Leaking heaps of air. Haven't dynod with problem fixed yet. But yeh. Initial duno was 150rwkw with just those mods. Hope that gives u some kinda indication.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
