7.92 @ 172 sammut bros 300zx.
sohc twin turbo rb30.
vehicle had 750 up to 1000hp
weight around 1000kg
that was all done years back, this thing is alot lighter then the vl commodores that are out there now, but the vls have extra power.
Just trying to find out if Rigoli's VL has gone quicker than the 7.97? or if anyone knows of a quicker RB30 car?
Rob
Yours you girl with some bigger injectors, nitrous and good 60' foot's.. or go the whole hog and use methanol, do it just to shut up the poms on gtroc..
"7's are imminent"
Mat. :thumbsup:
Didnt NIZPRO make a few quick RB30s?
They built a few 1000hp + Rb30dets years ago.
There are several 7 second Rb30ET VLs, the one that comes to mind is PANIC..7.9's over 5 years ago.
Rob, you'll have you hands full trying to hold the record. There's at least 2 skylines just in QLD that are looking at 6 sec territory.
Would be great to watch, just like the Melb Vl workshop wars years ago.
Edited by Alf
So there are Skylines (RWD presumeably?) aiming for 6s in Oz? Will be interesting to see... I know there were a couple of tube cars in the states running RBs - if I remember rightly one with a GT4788R and one GT5591R so they are clearly aiming for huge numbers with but all has been quiet for the last year or so on those builds.
  • 2 months later...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
