Wow, that's great. I thought about the same theory when I did my RB30, but I didn't dare pull that plug out for fear I'd never be able to find something to go back in there. Very good idea!!
  • 4 weeks later...
anybody else doing this mod?
im going to give it ago just wondering if there are any others out there who went with this method.
I did it after reading this post. Worked great! Plus, I got rid of my oil leak from the external oil fitting in the head. I had the hole in the head welded shut.
  • 2 months later...
The blue circle is the oil return port for the VVT.
The oil comes into there from the VVT valve and this port allows the oil to return to the head and drain away.
does that clear that up for you?
I pulled it out just to see what was in there! There is nothing that I can see in there that would/could be of any other use!
(but I did have to check! hahaahaa) Anyway, DONT pull it out unless you need to.. and I cant see why you would need to..
Feel free to take more pics and post them up..
I tried to give as much info as I could, so, you should be able to do the job without too much bother.
be kind to the plug when removing it.. you dont want to break it in half! or drill too deep!
happy modding mate!
Read the WHOLE thread again! check out post #4.
I put some colour on the bit that you need to look at!
Damn what was I looking at??? But in the pic you can see that mine has some sort of ballbearing on the outside, is the plug behind that? Would I need to drill into the ball and then somehow get something screwed in and pulled out and then tackle the plug?
I han't done a Neo head.. but I'm guessing that Nissan didn't stray too far from what they already know works.
Please take another pic, up close and front on, just like mine so everybody can see what your looking at.
hey just one more thing on this does it actually work because on the factory 25 block the vvt is getting a direct high pressure feed straight from the oil pump wheres this method is only getting in from the head?also when you other guys are putting the pistons in the block do you put oil on the rings or assemble dry 2 prevent the bores glazing up cheers chris nz :)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
