ive seen them go over 10500rpm constantly and never had a problem with them. I personally have ran them over 9500rpm nearly everytime i start my race engine and they free length and compession tested like new items on strip down.
something a bit more enlightening than saying something is shit would be appreciated.
maybe sometimes items are only as good as the way they are set-up/assembled
yeh my bad
drop them in out of the box (the way jun make them to be) they have too little seat tention. but then i guess if they were 'setup' aka made to work properly, theyd do the job.
in a big $$ head i dont like using parts that need to be made to fit/work, id rather use a part that out of the box works perfectly
yeh my bad
like my new favorites...you know the ones...the double ones.
does anyone in this topic make decent power @ 4000 rpm?
according to tyndago's (probably old) spreadsheet, boosted to the max, stock is
good for 250hp @ 4000rpm atw .. that is 180kw.
So I'm wondering if anyone close to 400kw can show 180kw at 4000rpm, or to look
at it another way, sees 1bar at or not long past 4000rpm ..
Street driving unless you're after a speed ticket or a noise violation I think is spent
mostly 1000-4000 rpm, I just spent an hour crossing sydney and despite consciously
trying, I found maybe two opportunities to hit 5000rpm without looking & feeling
like a tool. Ok maybe I look like a tool all the time, but you know what I mean. Street
it is mostly about 4000rpm.
Ill be able to say an accurate dyno figure very soon, get the car back in the next few days. Built 3L bottom, 270 cams, mild porting, ARC cooler, tomei dumps, hks exhaust, GTRS's on 2 bar.
Only thing left to do is add another fuel pump (only got one 044 intank) so thats holding it back
Ill be VERY suprised if it isnt making decent power @ 4000rpm. Gotta love the RB30 :P
Here is a dyno plot from a RIPS RB30DET setup running a Garrett T04Z that passes 180kw @ wheels before 4000rpm, definitely the most insane power delivery of any GTR I have been in. The dyno plot does it no justice, it feels like it pulls HARD from absolutely any revs - its nothing short of nuts.
thats pretty awsome..
oh and with the springs its not all about seat pressure :P
and paul/brad i was going to just blend the intake squish band to favour the exhaust.... but i decided to blend them both. and i do know a thing or two about engines.... r and d = common sence.
cheeres.
ps. as far as i was aware all cams over 10mm have a 29mm base circle?
cheeres.
yes
and yes
yes again
cheers to you
and also no JUN 10.5's and 10.8's (272's) are 30mm and also their 10.8 280's...the Tomei 10.8's we use are 30mm base also.
Edited by DiRTgarage
cheeres.
In no way doubting you Dave, didn't know if you did your own heads or gave them to someone else.
Is the head coming back off to do this or is it ready to drop 10mm+ cams in and go??
Edited by Risking
A good read in this thread, its really interesting to see how many different combo's there are making this power, different totally different setup's, and they are all different in there own way.
GREAT THREAD.....
There not skyline's still skyline motor's.
Sean's VL calais, RB30 with modified RB20 wiring loam and nistune
Full built engine, rods, piston's headwork ect, you know the drill
T04z
6BOOST manifold
48 progate
JD custon intake with ported runner's
Our own custom fuel setup's
3 1/2 exhaust
Full manual 4speed jatco, 4200 stall
518hp on 24psi pump.
My own VL calais
Full built, you know the drill, but $2500 on the head and cam, spec's custom.
6BOOST manifold
progate 48
35/40 1.06 rear
Rajab inlet with ported runner's
Our own custom setup fuel system's
Autronic Smc with dis4 MSD
Full built jatco with 3200 stall
Still on baby tune as we are moving shop and awaiting our mainline dyno mid feb, should see 480hp. (finger's crossed)
Edited by EFI Performance
yes! that is the point. good to see diferant combos. ps. if you havent caught it yet i cant stand "black art" engine specs... each to there own i spose :P
Black art???
What's that, hidden spec's or is that not aimed at me??
428rwkw
standard stroke rb26
garrett t04z on 6-boobs (24psi)
jun 272 10.5deg cams
the jun cams are carnts because of the base circle adjustment, it i was to do again hks 272 10.2 or tomei 270 10.2 would be used!!!
wat size rear housing did u use mate?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
