ive seen them go over 10500rpm constantly and never had a problem with them. I personally have ran them over 9500rpm nearly everytime i start my race engine and they free length and compession tested like new items on strip down.
something a bit more enlightening than saying something is shit would be appreciated.
maybe sometimes items are only as good as the way they are set-up/assembled
yeh my bad
drop them in out of the box (the way jun make them to be) they have too little seat tention. but then i guess if they were 'setup' aka made to work properly, theyd do the job.
in a big $$ head i dont like using parts that need to be made to fit/work, id rather use a part that out of the box works perfectly
yeh my bad
like my new favorites...you know the ones...the double ones.
does anyone in this topic make decent power @ 4000 rpm?
according to tyndago's (probably old) spreadsheet, boosted to the max, stock is
good for 250hp @ 4000rpm atw .. that is 180kw.
So I'm wondering if anyone close to 400kw can show 180kw at 4000rpm, or to look
at it another way, sees 1bar at or not long past 4000rpm ..
Street driving unless you're after a speed ticket or a noise violation I think is spent
mostly 1000-4000 rpm, I just spent an hour crossing sydney and despite consciously
trying, I found maybe two opportunities to hit 5000rpm without looking & feeling
like a tool. Ok maybe I look like a tool all the time, but you know what I mean. Street
it is mostly about 4000rpm.
Ill be able to say an accurate dyno figure very soon, get the car back in the next few days. Built 3L bottom, 270 cams, mild porting, ARC cooler, tomei dumps, hks exhaust, GTRS's on 2 bar.
Only thing left to do is add another fuel pump (only got one 044 intank) so thats holding it back
Ill be VERY suprised if it isnt making decent power @ 4000rpm. Gotta love the RB30 :P
Here is a dyno plot from a RIPS RB30DET setup running a Garrett T04Z that passes 180kw @ wheels before 4000rpm, definitely the most insane power delivery of any GTR I have been in. The dyno plot does it no justice, it feels like it pulls HARD from absolutely any revs - its nothing short of nuts.
thats pretty awsome..
oh and with the springs its not all about seat pressure :P
and paul/brad i was going to just blend the intake squish band to favour the exhaust.... but i decided to blend them both. and i do know a thing or two about engines.... r and d = common sence.
cheeres.
ps. as far as i was aware all cams over 10mm have a 29mm base circle?
cheeres.
yes
and yes
yes again
cheers to you
and also no JUN 10.5's and 10.8's (272's) are 30mm and also their 10.8 280's...the Tomei 10.8's we use are 30mm base also.
Edited by DiRTgarage
cheeres.
In no way doubting you Dave, didn't know if you did your own heads or gave them to someone else.
Is the head coming back off to do this or is it ready to drop 10mm+ cams in and go??
Edited by Risking
A good read in this thread, its really interesting to see how many different combo's there are making this power, different totally different setup's, and they are all different in there own way.
GREAT THREAD.....
There not skyline's still skyline motor's.
Sean's VL calais, RB30 with modified RB20 wiring loam and nistune
Full built engine, rods, piston's headwork ect, you know the drill
T04z
6BOOST manifold
48 progate
JD custon intake with ported runner's
Our own custom fuel setup's
3 1/2 exhaust
Full manual 4speed jatco, 4200 stall
518hp on 24psi pump.
My own VL calais
Full built, you know the drill, but $2500 on the head and cam, spec's custom.
6BOOST manifold
progate 48
35/40 1.06 rear
Rajab inlet with ported runner's
Our own custom setup fuel system's
Autronic Smc with dis4 MSD
Full built jatco with 3200 stall
Still on baby tune as we are moving shop and awaiting our mainline dyno mid feb, should see 480hp. (finger's crossed)
Edited by EFI Performance
yes! that is the point. good to see diferant combos. ps. if you havent caught it yet i cant stand "black art" engine specs... each to there own i spose :P
Black art???
What's that, hidden spec's or is that not aimed at me??
428rwkw
standard stroke rb26
garrett t04z on 6-boobs (24psi)
jun 272 10.5deg cams
the jun cams are carnts because of the base circle adjustment, it i was to do again hks 272 10.2 or tomei 270 10.2 would be used!!!
wat size rear housing did u use mate?
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
