Your seat, I never saw you get out of the car you lazy bastard. :)
Why, eye's letting go in your senior years?
Hahaha ok ill stop
In related news there should be two more 400 club members in the next few weeks, one an r33 gtr and one an r32 gtr
Hahaha ok ill stop
I'm hoping I will be a member as early as this evening.
I better or I'll probably get shot for the way I've hijacked this thread. :)
I havnt seen the graph yet Mike but we didnt quite make it to 400 kw. We did achieve everywhere else tho. Itys boosting hard and early and has shitloads more power under the graph.
Will get the before and after graph posted up tomorrow when I head over to the workshop.
Apparently we have run out of turbo so i guess the 1.06 housing is the next step.
And 380 somethin kw's was the number.
381rwkw is the highest we could get it.
Yes Gervase the air temp sensor is on the wall and you know why it is.
The boost falls over in the top end as the housing on the turbo is just too small. 1psi pressure drop in the cooler and an identical line it follows.
14 degrees of timing added in places where it used to be 0.
Going to put the EGT's on tomorrow to see what time she'll run on Saturday. 4th gear is happy in the pants on the highway too
Sees 1 bar at 3450rpm and 24psi at around 3800rpm but the graph doesn't show it due to the curve in the corner when the gate tries to catch up
Nice work Noel.
Did u change much to gain the extra midrange or was it tuned stronger compared to the other dyno graph that its comparing too?
We changed a fair bit Jez, Its a new head and a new fuel system running e85.
Its a work in progress and the goal is to hit the track next year with a fat 550/600 hp with the emphasis on fat. Piss easy to get that power with a bigger turbo but that isnt what I'm after.
The power chase will have to go on the back burner for a while now as I have too much other shit to do to the car.
In the mean time we will explore turbo options, I'm thinking a split pulse 1.06 rear housing for the 35r or possibly even a twin setup.
Still a great achievement there Noel. Its the response thats going to help out the most. Good Work!
Agreed mike, As you know that has always been the goal. I am stoked with the result.
We knew after the last go round that the turb would hold us back
, the 35r has its limitations with the smaller housing but it has made the path a lot clearer for us now.
Yeh I cant think of too many ways of achieving the 550/600rwhp mark with a gt35r, maybe a good split pulse manifold for starters, some wilder cams, though that will no doubt make the power more peaky which isnt really where you want it, but if you dont lose any low-midrange power then I wouldnt complain. Another possibility is one of those forced performance turbos with the billet comp wheels. However they are pretty exxy. And well a stroker of some description would definitely help with everything!
I'm hedging my bets on a split pulse setup. I wont change the cams. for the reason you mentioned,
If the split pulse setup can keep the response roughly where it is and give us another 50/60 ponies it will be more than enough to scare the crap out of this old man.
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
