What's been done? Alot! It even has a standard airbox! :nyaanyaa:
Note that crappy brown line is GT RS's. The red line is -5's. Boost controller is still off with the -5's. It seems with the modified actuators the controller on it doesn't like it. It would have been nice to hold 25 PSI the whole way but meh, its all good. It wont be the last time its on a dyno. I haven't driven it much, although as Steveo said, 265 Semi's and it turns them just rolling on the trottle in second. Turning tyres DOWN a hill is interesting also! I had a choice of backing the intake cam off for the 450 ish run but I was after area under the curve. What is interesting is taking off from lights without being an idiot. You don't realise how easy you pick up speed!
What rpm you on boost?
You've got big shoes to try and fill ;)
Here's a tip; my curve has it over Pauls - but thats for another day
paul - how do you compare your ride to my rb26/30? be honest as i wont be offended & no longer have that donk hehe
i'd like to see my dyno map overlaid on pauls map for comparisons sake...if anyone can do this, im happy to share it on this thread :)
any takers?
obviously with your consent as well paul.
Go for it.
Post it up in here and I will play with it tomorrow.
Yeah if you get some info for the bottom I'll do what I can
Already put mine over Paul's, the tune wasn't finished so I'm not posting it up, but I will say this, the trusty old RB30 is in front by a very decent margin.
Paul, Do you have any good photos of your exhaust system? Specifically, the front pipe. You run a dual 3 inch to single 4 inch, correct?
Twin 3 inch the whole way.
flick me your email and I will pass them on.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
