If you had to use a single turbo to make 400 - 450kw ATW, what would you use ?
GTX3582R, GT3788R, T04Z ???
gogogo !
Normally I would go the Z because it won't stop at 560-600 but the 3788 will spool faster. If you don't want any more than 560-580 then the 3788 is perfect, after that, the Z is still comparable for response with the 0.99 housing on the 3788
Alright lads,
Descision has been made.
http://www.gcg.com.au/AllImage/Products/Garrett%20Spec%20Sheets/gt3788r_772719-1.jpg
For those who don't want to click the link, it's the GT3788R from GCG here in aus, very reasonably priced too actually.
only question remains.
What rear ?
0.89
0.99
1.11
I'm thinking 0.99
Alright lads,
http://www.gcg.com.a...8r_772719-1.jpg
What rear ?
0.89
0.99
1.11
I'm thinking 0.99
Will you be going for low exhaust manifold back pressure and cams with some overlap? If you are, then go the larger rear housing but expect less performance at lower rpm.
If you don't have a lot of head porting and have zero overlap go the smallest.
I am not sure what the runner diameter of the 6Boost manifold and the lengths of the runners but that is also a consideration.
You need to choose which direction you want to set up your engine and turbocharger.
Low back pressure system: significant head porting, properly design tubular manifold, larger A/R turbine housing and camsahfts with some overlap... aim for 1:1 exhaust manifold pressure and boost pressure.
High back pressure system: the OEM turbocharger set up is a perfect example, higher exhaust manifold back pressure to boost (i.e. maybe 2/2.5/3.0 - 1), no overlap, short manifold runners, small A/R turbine housing.
You can't do a mix of both as each one will characterise how the engine will perform.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
