hey guys...
heh pardon my ignorance...
im drvin a 95 r33 gts...no turbo...:)
just wondering, occasionally, now that im informed by bam n sum otha ppl i can just pop by the plex on a sunday and do runs if i like, is there nething i shd be aware of?
like driving yr car hard prolonged could lead to this that this that...
an occasional whack to 180 on private roads? can spoil e car?
just wondering...if theres nethin i shd be aware of or shd not be doin till i do anythin to the car
thanks
:D
https://www.sau.com.au/forums/topic/25187-drving-hard/
not really unless you're doing circuit work....just watch out for the oil and water temps....
but for the occasional road excercises....there shouldn't be much of a problem...just keep your heater on for a few minutes should do fine...
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-535748
These cars are meant to be driven hard.
To me it's like asking if your BMW M3 can be safely* taken up to 250km/h (*mechanically speaking of course).
Skylines are supremely stable at very high speed. The motors are very responsive with the balance to go to the red constantly.
At speed I fear nothing for the car - just the police :)
T.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-535751
< snip >
driving hard? Talk about reading hard. :( That post was frikkin impossible to read.
But from the little I understood, no there should be no permanent damage as the car was designed to be driven hard. The occasional fang won't do damage unless the car's not been maintained well.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-536707
skylines love bring driven hard...
just keep good fresh fluids (engine, gearbox, diff, brakes, radiators), good plugs etc.
And of course, like fatz said, you need to get sump baffles installed if you want to go over 100km/hr.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537273
good point actually.. like how much punishment can a skyline take day in day out without it actually snapping? Do they start blowing smoke and things? I've never actually seen a skyline that looks "sick" but i guess they aren't at that age where that would become obvious I spose..
not that i really do that to my car, but just curious :P
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537425
the only answer is "depends", but I regularly take my stocker out on the track and use all of its potential when I'm out there.... never had a problem.
Personally, I think with quality fluids, stock boost and mixtures they can take plenty. Its when you move outside the tolerances that the manufacturer expected that you can have problems.
And don't forget a sump baffle.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537431
haha just take Gtrken for example .... takes a R32 GTR wth an awfully worn motor .... drags a Mits GTO .... yeah hurts it a little but it keeps solidering on ..... then takes it to JMS drifta-thon .... with clutch n engine worn gives it a good thrashng there .... starts makng weird noses after but it still soliders on
...... theres cars are meant for this over a long period of time .... sure theres going to be slight damage over time but for most part thats why they are called "performance" vehicles!! they are built for speed n an occasional hammerin ..... dont stress .... enjoy!! :D
....... i accept no liability in engine harm that comes from this advice :D
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-538309
A baffled sump will stop the oil from collecting at one side of the sump under hard cornering, which means you won't get oil surge. A baffled sump is desirable if you go circuit racing, but not really necessary for drag racing unless you doing 10sec or better:D
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-541196
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
