Yea, as Pat says... everyone will have difference opinions. Thats what makes modding cars so interesting. Look in the photography section. There is a thread full of R34's. You'll be able to see pretty much anything on offer there. Once you have made up your mind, then search for that :D
lol i hate the c west kit. im in the process of finding what combination i want and a friend of mine had just ordered herself a cwest kit [her bf ordered it] and i just wanted to know your opnions so i could show her.
i have seen a mad looking wingless yellow 34 with cwest front bar, and bomex sides and rear with the right wheels and other touches u can make it look really nice but then ive seen other cwest front bars look crap on other 34's.
Like Pattsy mentioned do A LOT of searching around and go for what u think would be sic and just do it. Problem with everyones opinions is that ur stuck with 140 opinions. Worse thing that can happen is that u dont like it, then just sell it if that happens. I would love to put my kit on that i have for sale but just want funds for wheels first. If i dont sell it soon i will just put it on and see how it looks.
Why would you want to show her our opinions.
Its obviously not a popular choice are you trying to make her feel bad or something?
shes taken it back to the shop and swapped it for a do luck one. im not sure where she gets her stuff done and she doesnt know much either. everytime i ask her its always i dunno my bf got it or my bf is doing it.
im so interested in car accidents ive been in about 7 accidents over the past 10 years
Hmm maybe you should look into a driving course before you even consider modifications?
not boasting. started a thread coz i saw an accident after work which i found interesting which got closed coz i didnt know what happened. found out last night that the guy was hit by 2 cars and died. so he wasnt passed out when i saw him laying on the road, he was dead...
also back ontopic. ive decided what combination i want and that is bomex back and sides with a top secret style 2 front. saw it on a dark blue 34 in the library car and it looked like a good match.
might need to make my car higher tho
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
