Well I just picked the car up from Mick @ Micolour who has finished fitting the new Z Tune kit and spraying the whole car.
It's come up brilliantly (pics don't do it justice - will have to get some better ones later but it's too hot out there right now). But I'm wrapped with how it's turned out :D
https://www.sau.com.au/forums/topic/252358-schmicko-has-done-it-again/
  • Replies 93
Posted Images
Looks really good :)
why didnt u get the front bar too finish it off?
The gaps in the side of the Nismo bar make the oil cooler less effective. Hence why we stuck to the standard front bar. (It is a race car afterall).
Well actually...who knows but articles i have read say that the slots will make the cooler more effective, hence why cars like Z-Tune etc have them. The side of the bar is a low pressure area meaning that if the oil cooler is ducted to the side of the bar where the opening is the vent will actually help draw air through the oil cooler core.
Ducting the oil cooler to the inner guard well , thats actually a high pressure area so you dont get great flow through the oil cooler when downstream of the cooler is a high pressure area. I have also read that ducting coolers there can lead to increase brake temperatures but even me the classic "i have no practical experience...i only nose what i nose from reading articles" thinks its a stretch to think that airflow from an oil cooler to the inner guard is going to affect temperatures and brake performance.
And, finally...I wish i had a big penis, was personally rich, good looks and any girl from the 2009 Raph Calender.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
