Sorry to resurrect an old thread, can i get some help plz....
I have got my new bosch 040 ready to go in.
I have bought fuel resistant hose and clamps.
I went to supercheap and they didnt have chemical resistant wire... where can i get some?
Could i just use the stock fuel pump wire and solder on terminals at the end?
Cheers,
Ryan
Is there any soldering required when installing a Walbro 255? (model GSS342)
Also do these aftermarket fuel pumps have a loud whine? I don't want anything louder than the Nissan OEM fuel pump.
My walbro whines, you can only hear it bad on ignition. Once the car is running or stereo is on you cant hear it much.
No soldering done with mine. Used the crimps that came with the kit.
  • 3 weeks later...
I used this how to as a guide and I just thought I might throw up a pic of the mounting job I did on my Bosch 044.
Had to pull it out once to readjust it cause it was making strange intermittent sucky noises which I could really only hear at idle when it was hot (afternoon). Cavitation ???
I tried to get the sock sitting at just the same height and angle as the stock pumps was.
It's only been a couple of days since, but I haven't heard the sound again... yet.
Seems very quiet in general, priming sounds tough. :thumbsup:
Edited by Not a Pulsar
  • 2 months later...
Hi Guys, I have a R33 GTR that I suspect has a dud fuel pump, I hve read the info here but I has going to check for voltage at the pump before I start to pull everything apart.
There is power at the fuel pump fuse, which conector is for the pump, the brown or the gray, I'm guessing the brown as it has only two connectors. Should there be power there when the ignition is turned to on or is it more complicated than that
Cheers
  • 1 year later...
I haven`t read the replies about all the fuel pump installations but why not save yourselves some drama and leave the standard pump where it is and buy an external one Attach it to the underside of the car or in the boot inline with the fuel lines somewhere,that way the standard pump acts as a lift pump and the new external does what its supposed to do!.That way you don`t have to get messy in the tank!.
What happens if and when the Old Stock Pump dies? Nothing good.
I replaced mine for peace of mind.
Gonna be changing my 044 for a Walbro soon. Just for fun. :thumbsup:
  • 4 weeks later...
  • 1 month later...
Could anyone be of some assistance?, I've searched but have not come up with anything concrete.
I recently changed out my fuel pump to a Bosch. When I turn the ignition on I can here it pumping, the car cranks but does not want to turn over.
I've pulled the hose off the filter and there is plenty of flow, not sure where to look next? possibly the AFM?.
any help is greatly appreciated.
Have you managed to start the car at all since changing the pump?
Is the pump wired straight to the battery with a relay?
Edited by dontyellpl0x
Are you sure you got the feed and return around the right way?
And I assume you mean the car cranks but doesn't want to run. The engine turns over when when the starter spins it?
  • 1 month later...
  • 1 month later...
just read all the replies,
imma bout to tackle the fuel pump change to a walbro 460 LPH. the thing is i think there is an 040 or nismo intank ...
thinking of just putting the new one external (external version of the walbro E85) and use it as a lift pump.
but for peace of mind i would rather change it but dont really wanna go through all the hassles tho.
but in saying that my fuel gauge works but not getting the warning light on low fuel?
cant be the low fuel sender kaput? coz the gauge still works but not the fuel light
already replaced the fuel light bulb and still nada.
any thoughts?
