123 is probably closer to around 340rwkw - but either way it's a good result. Bit better 60ft and it'll be much closer to the 11 end :down:
Interesting figure on that boost, you sure they are -9's though?
Only reason i ask is those figures seem more representative of -5's on a factory head from all the results in the RB26 thread and other threads (they are pretty much identical)
Once you spend a bit of coin on the head/motor etc then 20psi seems to deliver around 380rwkw give/take which would also correlate with your results :D
yeah you have a point i might add its a rebuilt motor freshened up with forged Mahle pistons and bearings pretty much a nissan engine with all the bolt on goodies to boot.
The -5s are they not a 350hp rated turbo i cant remember i just payed the bill and went by what i was told was the next size up. From what i have seen and heard the -5 seem alot laggier than how my gtr responds and from arond 2 yrs ago when i did it all the -9 where the imbetween of the -7 and -5 .
Unless the slight increase in cubic capacity has hit that figure easier then that may be the casw due to the slight hone and bore when the engine was rebuilt i dont know just a gtr lover who has spent shit loads on my prized possesion.
cheers,
Dave
Edited by Mr GTR-32
The -5s are rated @ 360hp turbo
The -9s are around 320hp turbo
The above are iff memory serves me correct of course haha, been a while since ive got digging. I think we might be onto something here :D
It would be approx 2.5-3 years ago the -9's were not a listed part. So it might be possible.
Also, the -7s & -9's are basically the same response. -9's just make a bit more power :)
Again not saying your result is wrong or anything as your MPH is indeed close. It's an interesting discussuion now you've said you purchased 350hp turbos? :down:
I have found my dyno graph and wsid docket grant will post these up some time when he gets them from me im hopeless at uploading pics etc haha, I defeinately have -9s R31 Nismoid checked my purchase docket as i purchased these through just jap and they are 320hp rated from Garrett.
Slightly slower Mph than i stated as it was a while ago but not far of i got a a 121.64Mph or 196Klms still good for 11 flat if i learn how to launch and go there with good tyres not crap lol.
cheers,
Dave
Hi all,
Dave have sent couple of MMS of the dyno graph and timeslip to me not long ago.
So there it is, you'll need to tilt your head for the graph :/ .
Cheers
Grant
p.s. Man, this is nice curve there.
cheers,
Dave
Thanks for checking :D
Given the dyno graph is a tad "high" by the IT correction, you have around 320-330rwkw and MPH backs that up nicely.
Good result for 18psi with those turbos!
You are also loosing 2psi towards the top end - you might want to get boost control looked into as it would make it hold even harder to redline if it didn't start falling away after around 5300rpm :miner:
Yeah boost drops of i am running an eboost 2 what would i need to do to hold the boost better change EBC which i dont want to do they are sp damn expensive.
Well i hope this backs up my experiences with the -9s they are awesome, next time round its head work and some -5s been told with some minor head porting and good cams they to hopefully wont be to laggy. But thats a while away for now ill stick with the sharp response of what ive got.
cheers,
Dave
cheers,
Dave
What's the pre-load set to on the waste gates? Are they set to the same pressure?
Are you driving around on the same boost setting all the time?
Straight from turbosmart's website:
the maximium boost pressure (set point), the spool up rate of the turbocharger (gate pressure) and the reaction time of the controller (sensitivity).
You should be able to help level it out using the gate pressure and the sensitivity.
I'm looking at fitting a set of -5's, and I have a question on the side:
My car is already tuned at 18psi, power fc. When I install the -5's am I able to drive the car at WOT within the 10-18 psi bracket before a new tune?
I know that I should (and obviously will) get another tune, but I want to get some cams first before putting $$ into dyno. Just putting the question out there.
If it's related to airflow, instead of boost (AFM's) - Will it drive at WOT using lower boost since (my pure example) the total airflow will still be within the tuned range?
(The way I figured is as long as I stay within the table on the power fc (not too much rpm or air flow) and everything is still safe?)
Edited by GTRPowa
18psi from a pair of -5's and 18psi from say -9's is completely different, sure the intake system is pressurized the same as 18psi, but the -5 will be flowing alot more air than the example -9.. the engine has no idea what psi the turbos are running at, only about how much air is passing through the AFMs
Hence the other half of my question, if I run at a lower boost, whatever amount needed that I'm not going off the charts on my Air Flow resolution on my tune, then it's ok for a temporary basis?
How about you just take it easy like any other person would?
Kepe rev's below 3000-3500rpm until you have time to get it all checked correctly? Best course of action in my book :blush:
Better yet don't drive it at all :blush: is it worth the risk really ?
Also as for -5's with a built motor and some go fast bits I see no reason why 430-460AWKW can't be acheived :blush:
Edited by Nee-san
I'm not familiar with the eboost 2 - but if there are some gain settings to alter, that would likely help.
Talk to your tuner mate, they would have the best idea about it if they set it up initially :blush:
Post 18 of this thread shows my car running an eboost 2. It has rpm input so you should be able to get it to hold full boost all the way to the redline. Mine does. Like Ash says, your tuner should be able to fix this and you shouldn't need another EBC.
http://www.skylinesaustralia.com/forums/St...ds-t280020.html
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
