Lol! My -9's didn't come with actuators, and I thought I could 'cheat'. Nope you gotta spend the $$$ lol.
Yeah, the nasty compliance cat won't be there for long, but I will still run a cat as I'm soft and don't want the hassles....
Okay. Got a tune done the other day.
Bad news is the stock actuators I put on the -9's can't control the wastegates properly so the boost is wavy lol, even boost controller couldn't keep it steady.
So new stronger adjustable one's are on order.
So good news is the car runs pretty well now and good response, mid range torque is great!
Boost peaked at 18PSI and 288RWKW @6500PRM to 8000.
10psi at 3300
15psi at 3700
18psi at 4000
16 at 4900
15.5 at 5300
16 at 6400 etc.
So that was with stock intake, stock fuel system, stock AFM's.
Non standard parts: boost controller, -9's, Power fc, intercooler, front pipe, and 3 inch cat back, and compliance cat.
interesting... im getting 270rwkw at 15psi
almost the same mods as yous... except no boost controller, cooler or front pipe
lol that boost curve is all over the shop
i've bought a metal racing cat which i will 'modify' for more flow and looking for a decent front pipe...
once those are in my boost should come on as early as yours
then to get some AFMs n injectors n put 20psi through it :D
hey probably noobish question here guys but will the actuators that came with my -5's be able to control boost properly once i get my pfc/injectors in and turn the boost up?
I'm only planning to run 18psi.....or so.
Under 20psi makes baby Jesus cry
Lol
What are your thoughts on them compared to the r32 setup now you've had them tuned etc and it's a more of less fair comparison until you build the motor and turn it up :D
Ha ha Steve-o, yeah 25PSI feels strong lolz!
This setup feels a lot more alive, especially in the twisties. Found that I could stay in a higher gear and not have to rev the guts out of it. It was hitting 18psi around 3600 or so in 3rd and 4th etc when I glimpsed at the display accelerating up slight hilly corners tonight. In a straight line though, it doesn't feel as aggressive as the 2530's on the 32, but the speedo says otherwise....
I liked the way the 2530's came onto boost and charged towards 8000rpm, but there wasn't much happening under 5000rpm, so the 34 with the -9's do work out well, and is just as fast as the 32 with less hp. I wanted more under the curve this time and considering the 34 is heavier, it worked out well. Ploding along in traffic is easy and I find I don't need much throttle to get going.
When one of my mates was driving back in his car after we picked up my car, he said that he could hear the tyres ripping into the road when I accelerated in 1st and 2nd gears, I just laughed as I thought it was funny, but it really has got a nice strong torque band.
Injectors are on 92% duty so there is a little left in them.
Better actuators are on order and a better cat converter. I'm sure this will make it a little better again, so I'm happy with the results.
Yes that's how I would expect these -9/GTSS turbos to work . The reason why they feel good is because they make good torque at lower revs so you don't have to chase high revs to get some pull .
Yes the 2530 and similar dryers make the numbers buts that's because the higher RPM numbers artificially raise the Hp/Kw number . Torque is the measure of turning force and more torque means more acceleration and yes the ability to pull higher gears from the lower mid range engine revs wise .
Eventually people tire of being impressed by high revs and want things that haul from lower revs , often just as fast but a LOT easier to drive and live with .
The feller in the post above I'm sure can understand what I mean when I say these turbos to a degree mimic a larger capacity engine which is what GTRs always needed . With stripped out tarmac racers no one cares what happens south of 4000 revs but when in road going guise that tonne and a half takes some moving when stopping and starting and slothing around in today's traffic levels .
I personally think anyone who wants a fast std capacity road weight GTR has rocks in their heads for not using these turbos . These are good road cars units , maybe not so good for drag or a real racer buy they are so far divorced from what makes a road car good as to be irrelevant .
Your opinions your calls , I don't like/have GTRs but if I had to have one they are what I'd use on the street .
A .
Awesome, cheers!
Whats better out of -7s and -9s or am I silly for asking this question? Looking at options for my street GTR (which sees a track every couple of months) and looks like everyone loves the -9s and thinks -5s are too laggy, I am very tempted to buy some new -5s cheap off a member here but don't want to regret it?
If I had the following basic mods:
full exhaust including 3" straight through cat, stock dumps
cam gears
power fc
apexi pods
What would you do and would you do more things at the same time to make it more worth while?
Leigh,
Go for -9s, you won't regret it, you're welcome to ride in my R before you decide if you want (that'd have to be next week as I'm moving houses tomorrow and rest of this weekend - late night may be a option).
Have you changed the clutch yet?
Done 100,000km service?
That's all I can think of for now.
Cheers
Grant
Ill be doing the 100k at the same time probably get a kit from Kudos or something, getting some quotes for -9s as well I think they would be best a lot of people think, as for clutch I'm not sure whats in it.. should I wait for it to go bang or what? lol
And yes I will take you up on that ride offer I think! coming to apple peel tomorrow night? if you can make it that would be sweet :D
hells yes Hamish :D its been a while since I've entered a deca and it will be the first time in a turbo charged vehicle so will be interesting to see how I can handle the extra power and if I can put it all down
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
