Other thing is the turbos are REALLY laggy.
I get 18psi by 6000rpm and power drops off completely at 22psi at 7500rpm so theres no point revving past there...
Has it been tuned? If it has I'd be finding someone else to tune it.
I think this is your issue as well.
Is the engine healthy i.e. done a compression test as this could be the source as well? Your tuner should have diagnosed if there was an issue from the onset.
It can be low reading all it likes. 18 psi at 6000 rpm then falls over at 7500 is the issue.
This is the dyno chart. If you could interperet it that would be great.
Sorry its not in RPM. If it helps, I've got an RB25 box and 4.08 gears.
Edited by TheGeniusMoose
R33GTR motor. 155PSI compression on all 6
2860-5 turbos
255L walbro pump
Nismo 600CC injectors
RB25 box and 3.08 diff gears
Coppermix clutch
STD r33 GTR FMIC piping
Power FC D Jectro
Greddy Profec B
8psi actuators
Is that what you need to know?
What turbos are they?
What's the rest of the setup?
2860-5 turbos
255L walbro pump
Coppermix clutch
Power FC D Jectro
Greddy Profec B
8psi actuators
Also need exhaust details. You should have minimum 3.5in with metallic matrix cat. Take a look at the RB26 sticky to see what you should be getting - something is seriously wrong with your result. Injectors might run out of puff if they're not clean.
Twin 3" dumps into a 3.5 decat and 3" cat back
I'd have thought cam gears wind a bit more response in and not a whole heap of power. Regardless... something in my current setup is very wrong without buying new stuff I think.
Depends which way you turn the gears.
Here is a question for you rev heads.
My build comprises of the following:
Tomei Advance Spec RB26 (long engine) spec are here http://www.tomeipowered.com/BTE/index.php/2011/04/28/rb26-complete-engine-advanced-spec/
Garrett 2860R -5s (ex. housings lightly ported)
HKS actuators (set at 1 bar each)
OEM ex. Manifolds (ported)
Mines dump Pipes (Pipe diameter: 70φ)
Midori Ti front pipes (80φ diameter)
Catco Race Cat (3' diameter)
Tomei Ti Expreme cat back exhaust (3.5' diameter)
HKS fuel rail
HKS 1,000cc injectors
Tomei fuel pressure regulator
SARD Intank Fuel Pump (280ltr p/h) (in bold because I believe this will be a weak point)
Nismo Plenum
Cooling Pro I/C (100mm)
Apexi Power FC + HC
To be tuned on E85
Boost say 20psi
What power do you think I should make? and do you think that choice of -5s is appropriate?
Why have a 3 inch cat ? Make it the same size as your catback.
I thought that would be restriction....where can I get a 3.5in cat back from?
And why only 20 psi. IIRC, those Tomei engines are 8:5:1 (correct me if I'm wrong). 24 on pump fuel!
20psi was just an estimate
Advance spec is 8:4:1 (same as Tomei 2.8 Genesis) if that changes anything???
Edited by Ants
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
